car not starting/ to much fuel
Old May 1, 2011 | 01:23 PM
hatche1's Avatar
Default car not starting/ to much fuel
Okay so i finally finished my turbo setup on my hatche but now the car doesn't want to start. My hatche was running prefectly fine before i installed the kit. When i installed the kit I had also installed 750cc satuarted injectors and a walbro 255lph fuel pump. So when i go to start the car, at first it tends to want to turn on and then it just keeps on cranking and gets flooded from fuel. So with that said is ther a way to give the motor less fuel so it can start? So i have to run a fuel pressure regulator or get my ecu to give the car less fuel?
Old May 2, 2011 | 09:39 AM
hatche1's Avatar
Default Re: car not starting/ to much fuel
Anyone got any advice?
Old May 2, 2011 | 10:26 AM
anavrin's Avatar
is it tuned?
Old May 2, 2011 | 02:23 PM
jrp355's Avatar
idk if this applys to you but i think with those injectors you need to solder in a resistor box from the 89-92 crx,ef,accord.
jrp355's Avatar
but yes a tune (base map minimally) should be done before hand
Old May 2, 2011 | 08:03 PM
hatche1's Avatar
Originally Posted by anavrin
is it tuned?
its not tuned its just on a basemap.
Old May 2, 2011 | 08:07 PM
hatche1's Avatar
na i don't need a resistor box. i had got these injectors making sure i didn't have to run a resistor box. i found out i am going to have to get the car tuned to run the 750s so hopefully i can get a tune soon. thanks for the help peeps
Old May 2, 2011 | 09:54 PM
wantboost's Avatar
Who is Mr Robot?
if the basemap is scaled for 750s it should crank and idle... sounds like you just have a generic basemap
Old May 2, 2011 | 10:13 PM
GoSickemRobert's Avatar
make sure the map sensor isnt mixed up with the tps clip and that the clip is okay
and yeah what everyone else was saying, make sure the basemap accepts the 750s
otherwise is gonna just shoot that fuel in there.
Old May 4, 2011 | 06:15 AM
Pharaoh's Grim's Avatar
might b too much pressure for the spark
Old May 4, 2011 | 04:32 PM
hatche1's Avatar
well my tuner set me up with the chip and to the specs of the car. my tuner is coming over to check it out and i'll update y'all on that it is.
Old May 8, 2011 | 03:01 PM
wantboost's Avatar
Who is Mr Robot?
on start up? learn physics and how to read or kill yourself
Old May 8, 2011 | 10:18 PM
hatche1's Avatar
ya on the start up.
Old May 8, 2011 | 10:25 PM
hatche1's Avatar
well we found out the problem was that the injectors were over killing the car so i put the stock injectors on just to get the car to idle so i could make sure i didn't have any other problems with the car before my tuner came over to actually tune the car for the 750's to work with my setup.
Old May 9, 2011 | 04:35 AM
Old May 9, 2011 | 05:09 PM
wantboost's Avatar
Who is Mr Robot?
Originally Posted by hatche1
ya on the start up.
no amount of fuel pressure will blow out a spark on start up.... it turns into an atomized mist upon exiting the injector. the only thing that will happen is over fueling if the basemap isn't scaled for the 750's which is what appears to be the case
Old May 10, 2011 | 08:00 AM
welfarepc's Avatar
open your tuning software and lower the post start and cranking fuel trims
Old May 10, 2011 | 04:52 PM
hatche1's Avatar
o also my ecu was bad so the ecu was running as a stock ecu and not a chipped ecu with my custom basemap.
FW_EJ8
Jan 29, 2010 09:18 PM
HondaKid936
Nov 25, 2008 02:09 AM
EGNA
Jul 12, 2006 03:31 PM
lsvtecna
Mar 25, 2006 06:47 PM
