Car is losing injector ms and lean cutting??
I am new to the honda game and have a turbo b18 and when it hits full boost it starts losing injector ms and its causing it to lean cut. The car was tuned recently and was running good and this just started happening. Has anyone experienced something like this and any ideas on what could be causing it?
Re: Car is losing injector ms and lean cutting??
Originally Posted by jessejames309
(Post 52825662)
Originally Posted by JRCivic1
(Post 52825710)
What do you mean by "it starts losing injector ms" ??? How much is "full boost" ??? Is this the same PSI as when the car was tuned ? Tunes don't change themselves, so unless you got in there with your laptop and started mucking with things... the problem is in your car. Something changed... meaning either you swapped some part or parts OR something is broken.
Deff get your Injectors flow tested and cleaned to rule that out, Also check the wiring but you might have a injector thats clogged or poor flow. Also look into the burton racing fuel pump relay.
Fuel Pump Upgrade Harness – Burton-Racing |
