car keeps dying
Old Apr 4, 2009 | 07:04 PM
malink's Avatar
Default car keeps dying
heres my problem,
Everything on set up is clean and running. When we start the car, it idles for 15 seconds then dies but if we try and give it gaz is just die.
civic 1995
h22a 1994
ECU P28 tune eCtune PrecisionAutoCanada.com
6 psi boost
Turbo Holset T3 hx35w
intercooler XS power
Kit 'injection de water-methanol
Injecteurs Precision Turbo 880 cc
Ligne 3" complete mandrel
Downpipe 3"
Piping complete intercooler aluminium 3"
Intake ported
Wastegate 38 mm
Gasket intake Hondata
tensionneur H23
piping cx racing
log manifold
Walbro 255
Filtre a essence
Timing belt + balencer belt
The SRS light if always flashing in the dash and the check engine code is for vtec solenoid
we change the sparkplug, wire, cap
any help?
Old Apr 4, 2009 | 09:26 PM
malink's Avatar
Default Re: car keeps dying
any help?
Old Apr 5, 2009 | 05:03 AM
Joseph Davis's Avatar
Has the car run before with this setup? What was the last thing you did to it before it started having problems?
Old Apr 5, 2009 | 05:19 AM
malink's Avatar
the setup ran perfect im my other civic
we are redoing the wiring right now...
Old Apr 5, 2009 | 06:55 PM
malink's Avatar
any infos?
Old Apr 6, 2009 | 03:56 PM
malink's Avatar
we put the stock injectors and stock ecu
still the same problem...any ideas?
Old Apr 6, 2009 | 07:40 PM
malink's Avatar
ok, we put the stock map sensor, ecu, injectors
can ran fine
now we are redoing the 2.5 bar motorola map wiring and putting everything back together and hope its work
Old Apr 7, 2009 | 03:47 AM
malink's Avatar
we reput everything (tune ECU, 880cc precision injectors, map sensor) and the problem is there. Maybe the map is defect or the ECU doesnt recognize the map sensor
any help?
Old Apr 7, 2009 | 09:14 AM
B16Civic93's Avatar
when i used the 2.5 bar motorola map sensor i had alot of problems with it, i switched to a gm 3 bar and the problems went away... that is my suggestion to you. hope it helps
Old Apr 7, 2009 | 09:56 AM
malink's Avatar
ye,
I'm trying to find some feedback about the map sensor put cant find any
If i change my map sensor...for a gm 3 bar map, do i need a retune or can i just go in ectune and choose gm 3bar map insteed of 2.5
Old Apr 7, 2009 | 10:05 AM
malink's Avatar
weird thing is that everything was fine in the other civic with this setup. Maybe we damage the map (looks pretty cheap) when we swapped everything
D-Rob
K Series
103
Oct 30, 2015 05:56 PM
malink
Engine Management and Tuning
Apr 7, 2009 02:56 PM
punkinbeck
Sep 26, 2007 03:58 AM
yardy8301
Jun 18, 2007 07:19 PM
