car idling up and down
heya guys
my car at the moment does not want to idle properly, its idling up and down like a ****, any idea what causes it ???
does running rich on idle will cause that sort of problem ???
its full built b18c1 with JG manifold
thank you
thank you
with the car running and jumping like that look inside the stock throttle body.
there are 2 holes on teh left side
take your finger while the car is still running and plug the top one. if that fixes it replace the iacv
if not plug try to plug the bottom one. if it stops now the its the fast idle valve
if its the fast idle remove it and take the end closes to the firewall off. inside screw it all the way in and replace the fast idle back on the car.
should be fixed
should be fixed
mateku
Nov 24, 2015 03:26 AM
screen_name
34
Sep 19, 2005 01:10 AM
autoxthis
Feb 12, 2004 09:17 PM
