Car does not boost
Old May 9, 2006 | 10:47 AM
em1 Ziggy's Avatar
Default Car does not boost
can anyone tell me all the problems of why my car isn't boosting...
i know IC pipings is one...
Vacuum line..
open waste gate.. are there any more i can double check in my car.. my car spools but not that much... but it doesn't seem to build enough pressure to make the waste gate bump.. anyone know what can be the problem...
BTW im running a t3/t40e turbo.. 57 trim.. 450 CC DSM... walbro 255 fuel pump.. Blitz BOV. Golden Eagle Vacuum Manifold..
Modified by em1 Ziggy at 2:26 PM 5/9/2006
Modified by em1 Ziggy at 2:27 PM 5/9/2006
Old May 9, 2006 | 11:50 AM
yee SERIOUS's Avatar
is your turbo ok? last time my turbo stop spinning
Old May 9, 2006 | 12:29 PM
em1 Ziggy's Avatar
Default Re: (undercoverdc2)
its a brand new turbo.. i just bought it.. i took the filter out and it looks like its spinning
Old May 9, 2006 | 01:00 PM
Dc4turbo408's Avatar
Default Re: (em1 Ziggy)
Check your IC pipings again, recheck everything u did make sure everything is tighting.. I had the same problem, went back to check wat was wrong.. One of the ic pipin wasnt tightin enough..
Old May 9, 2006 | 01:14 PM
em1 Ziggy's Avatar
Default Re: (LsvtecBoi408)
everything seems to be tight still no boost my boost guage reads at 18 in vaccuum i've sprayed water everywhere anyone live in LA to check it out! This thing is a headach
Old May 9, 2006 | 01:16 PM
Schister66's Avatar
Man U FTW
do you have the wastegate hooked up correctly....if you have the vac line on the top port, you will have problems
Old May 9, 2006 | 01:20 PM
em1 Ziggy's Avatar
Default Re: (Schister66)
ill take a picture of everything
Old May 9, 2006 | 01:27 PM
em1 Ziggy's Avatar
there pictures up are my vacuum lines retarded or anything someone help!
Old May 9, 2006 | 01:44 PM
B18C4-T's Avatar
The vacuum lines look ok, make sure the diaphram in the wastegate isn't torn. I used a wastegate line kit and the fitting tore my diaphram, I looked for a long time and finally tore it apart and found that. Also check and make sure the wastegate is sealed to the manifold. Just move your hand around the flange with the car running to see if you feel any air. I never run the wastegate gasket because I used to have problems with them blowing out.
Larry
Old May 9, 2006 | 02:08 PM
RogueWorks's Avatar
Default Re: (B18C4-T)
dude, plug your open port on the vacuum manifold
Old May 9, 2006 | 02:35 PM
tallyturbo's Avatar
Default Re: (RogueWorks)
^^^ why? he prob didnt drill a hole through it.
Old May 9, 2006 | 02:37 PM
em1 Ziggy's Avatar
Default Re: (tallyturbo)
yup didn't drill a hole im about to take my wastegate apart.... and see what happens.. but i think its my turbo cuz it spools... but i've seen smaller turbo's spool harder then this....
Old May 9, 2006 | 02:47 PM
was it boosting right before?
Old May 9, 2006 | 02:51 PM
lucidvtec's Avatar
u need a plug in that vacuum mani
Old May 9, 2006 | 03:02 PM
havok hybrid's Avatar
Default Re: (lucidvtec)
i would put all my money on your wastegate. I bet its not holdin anything.
Try another one.. or open that sucker up.. nothing is inside that you can mess up.. opent he wastegate up..
Sounds to me the wastegate is stuck.. or you have a whole in your intercooler or something..
Does the boost gauge try to read boost 1 or 2 pounds?
Old May 9, 2006 | 03:03 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (havok hybrid)
do you have a valve seat on your WG?
Old May 9, 2006 | 03:06 PM
em1 Ziggy's Avatar
Default Re: (boostincoupe)
its something im getting no boost at all on the boost guage
Old May 9, 2006 | 03:15 PM
Soccerking3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">do you have a valve seat on your WG?</TD></TR></TABLE>
yea do you have the fire-ring in there?
Old May 9, 2006 | 03:19 PM
i was thinking the fire ring too. but i thought he was was boosting before?
Old May 9, 2006 | 03:45 PM
em1 Ziggy's Avatar
i was never boosting at all... yes the fire ring is one look this is how it looks second picture.. what u guys think about my waste gate? is it good?
Old May 9, 2006 | 03:50 PM
Default Re: Car does not boost (em1 Ziggy)
it looks fine, when the spring is in there is it hard to puish up the plunger?
Old May 9, 2006 | 03:52 PM
em1 Ziggy's Avatar
Default Re: Car does not boost (Soccerking3000)
yeah really hard
Old May 9, 2006 | 04:28 PM
jtracing919's Avatar
i had a similar problem, my filter was to restrictive and it wouldnt make boost. all so check for pre turbo exhaust leaks.
Old May 9, 2006 | 04:38 PM
em1 Ziggy's Avatar
Default Re: Car does not boost (jtracing919)
how do i check for pre exhaust leaks?
Old May 9, 2006 | 05:01 PM
em1 Ziggy's Avatar
well my downpipe has a leak cuz i don't have a gasket inbetween in but i heard you don't need a gasket ..
