can you re-use arp headstuds?
Old Jul 24, 2006 | 11:44 PM
budget's Avatar
Default can you re-use arp headstuds?
Old Jul 24, 2006 | 11:49 PM
komat's Avatar
Default Re: can you re-use arp headstuds? (gold)
like 3 or 4 times
Old Jul 25, 2006 | 12:01 AM
ImportMotorSpec's Avatar
Default Re: can you re-use arp headstuds? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">like 3 or 4 times</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">like 3 or 4 times</TD></TR></TABLE>
Old Jul 25, 2006 | 03:37 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">like 3 or 4 times</TD></TR></TABLE> Has this been verified through measurements that these stretch after 3 or 4 times?
Old Jul 25, 2006 | 04:23 AM
BoostedEG6's Avatar
Default Re: can you re-use arp headstuds? (dr_latino999)
I have reused a set 4 times and never had any problems.
Old Jul 25, 2006 | 04:51 AM
Soccerking3000's Avatar
Default Re: can you re-use arp headstuds? (BoostedEG6)
you can use them an infinite amount of times as long as they arent overtorqued and undergo plastic deformation causing necking/thinning of the rod. People who say 3-4 times you do not understand metallurgy...
Old Jul 25, 2006 | 07:19 AM
1epmugenlude's Avatar
Im reusing mine, and it will be the 3rd time. Guess its time for a new set next time.
Old Jul 25, 2006 | 07:40 AM
Boostage's Avatar
U must be thinking arp rod bolts. head studs you can keep reusing.
Old Jul 25, 2006 | 07:43 AM
RyanEJ8's Avatar
Default Re: can you re-use arp headstuds? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">you can use them an infinite amount of times as long as they arent overtorqued and undergo plastic deformation causing necking/thinning of the rod. People who say 3-4 times you do not understand metallurgy...</TD></TR></TABLE>
Old Jul 25, 2006 | 08:12 AM
rtype11's Avatar
I believe most ARP headstuds are of the torque to yield type, this means if you follow their torque and lube procedure correctly and do not over torque you can use them an infinite amount of times. once over torqued passed their yield limit they will stretch and lose their strength. best to measure them precisely once purchased and everytime they are reused to make sure they have not stretched. call them with any questions as i once called about their torque recommendation for using oringed copper gasket and arp lube vs 30 weight oil, the torque required was like 30lbs more than in their insallation guide.
Old Jul 25, 2006 | 09:35 AM
Default Re: can you re-use arp headstuds? (rtype11)
actually if you over torque them they will undergo strain hardening, which to a certain point will make them stronger, but more brittle, which is a bad thing even though they have a higher tensile strength.
Old Jul 25, 2006 | 10:57 AM
vtec.dc2's Avatar
Default Re: (1epmugenlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1epmugenlude &raquo;</TD></TR><TR><TD CLASS="quote">Im reusing mine, and it will be the 3rd time. Guess its time for a new set next time.</TD></TR></TABLE>
2nd time here
Old Jul 25, 2006 | 11:02 AM
rtype11's Avatar
will make them stronger but not uniformly and impossible to gauge correct torque value for reuse - work hardened studs are garbage.
Old Jul 25, 2006 | 05:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">will make them stronger but not uniformly and impossible to gauge correct torque value for reuse - work hardened studs are garbage.</TD></TR></TABLE>
correct but just wanted to state that
SiRidiculous
Mar 21, 2007 06:26 PM
s2kboii
Honda S2000
67
Sep 7, 2005 09:10 PM
Son99ek
Oct 5, 2004 05:19 PM
adrenalinjunkie
Jul 2, 2004 12:49 PM
1point5CRX
Mar 1, 2004 06:14 PM
