Can turbocharging INCREASE fuel efficiency?
Old Nov 10, 2004 | 10:36 AM
fredtoast's Avatar
Default Can turbocharging INCREASE fuel efficiency?
I've heard that turbocharging can actually increase fuel efficiency. Is this possible? Since you have to add extra gas to all of that extra air I don't see how it could increase the actual MPG.
Old Nov 10, 2004 | 10:39 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Can turbocharging INCREASE fuel efficiency? (fredtoast)
yes it does increase full effiency when your not in boost......im assuming better atomization.
Old Nov 10, 2004 | 10:49 AM
Adi Radoncic's Avatar
On Fire!
The answer to your question is pritty much a yes no answer because its really all in your tuning.
Any car will burn has morre efficiently if you lean it out some and a degree or two of timing..
Turbocharging just stuffs more air into the cylinders to get you more power.
Adding one isn't really gona help your gas milage because you will be burning more fuel to compensate for the air jammed into the cylinder..
You get what I'm saying?
Old Nov 10, 2004 | 10:58 AM
turbo*s2k's Avatar
Default Re: Can turbocharging INCREASE fuel efficiency? (newgsr)
I think it's in the tuning! Naturally you are going to waste more gas when your on it, but out of boost if tuned part throttle you can get better gas mileage.
Modified by TurboChrgd_Civic at 12:21 PM 11/10/2004
Old Nov 10, 2004 | 11:00 AM
Casey's Avatar
Default Re: Can turbocharging INCREASE fuel efficiency? (TurboChrgd_Civic)
we noticed about 75-100 more miles a tank on a friends crx, thats including getting on it a few times a day. setup was a junkyard kit, 450s, afc hooked up normally with base settings and no dyno tuning
Old Nov 10, 2004 | 11:19 AM
RyanEJ8's Avatar
Default Re: Can turbocharging INCREASE fuel efficiency? (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">we noticed about 75-100 more miles a tank on a friends crx, thats including getting on it a few times a day. setup was a junkyard kit, 450s, afc hooked up normally with base settings and no dyno tuning</TD></TR></TABLE>
Did you lean it out a bunch at part throttle or something? That sounds kind of odd with the bigger injectors and afc that your MPG would improve that much.
Old Nov 10, 2004 | 11:29 AM
Casey's Avatar
Default Re: Can turbocharging INCREASE fuel efficiency? (RyanCivic2000)
i cant remember the exact settings we did, but it was like -45 across on low throttle and -35 across on high. this was a while back, it may not have gotten 100 more miles, but i can remember him saying he got 75 extra per tank, still getting on it like normal, ill ask him later about settings
Old Nov 10, 2004 | 01:08 PM
ATS*Mark's Avatar
OG triple OG
i get almost 200 miles to the quarter tank , just like i did before turbo and this is with 750's
Old Nov 10, 2004 | 01:26 PM
J337_UNIT's Avatar
Default Re: Can turbocharging INCREASE fuel efficiency? (OnePointSicks)
im getting about 250 miles to the tank, but i get on it quite frequently and theres lots of stop and go driving.
Old Nov 10, 2004 | 01:28 PM
SunspecV's Avatar
200 to the quearter tank? i call bs
Old Nov 10, 2004 | 01:31 PM
mopar junkie's Avatar
how does adding a big exhaust restriction increase fuel economy?
Yes a turbocharged engine will be more economical for the power it can create vs. a big displacement NA motor. But just taking your 40mpg honda and adding a turbochager will not yeild 40+mpg. Not gunna happen.
Old Nov 10, 2004 | 01:40 PM
RyanEJ8's Avatar
Default Re: Can turbocharging INCREASE fuel efficiency? (SunspecV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SunspecV &raquo;</TD></TR><TR><TD CLASS="quote">200 to the quearter tank? i call bs</TD></TR></TABLE>
Me too. That would be like 70 MPG. Not gonna happen.
Old Nov 10, 2004 | 01:45 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnePointSicks &raquo;</TD></TR><TR><TD CLASS="quote">i get almost 200 miles to the quarter tank , just like i did before turbo and this is with 750's</TD></TR></TABLE>
u realize thats like 800 miles to the tank?
Old Nov 10, 2004 | 01:48 PM
AzG35's Avatar
I think he means 200 to the spot where there is a 1/4 tank left.
Old Nov 10, 2004 | 01:49 PM
RyanEJ8's Avatar
Default Re: Can turbocharging INCREASE fuel efficiency? (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">I think he means 200 to the spot where there is a 1/4 tank left.</TD></TR></TABLE>
That's believable. Kind of an odd way to say it though.
Old Nov 10, 2004 | 01:53 PM
m R g S r's Avatar
Whaaa? That's 800 miles a tank. And I'm assuming you still have the stock fuel tank, right? That's no larger than 13 gallons. Nooo way that's right. I get about 200miles a tank, but I'm always on the throttle. Anyone with a boosted car is, no matter what. If you can resist, then I give you props.
Old Nov 10, 2004 | 01:54 PM
SunspecV's Avatar
Now that makes sense....I was gonna say, I know honda's are good for fuel efficiency and all but 800 miles to the tank, BY GOD!
Old Nov 10, 2004 | 01:57 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
That's believable. Kind of an odd way to say it though.</TD></TR></TABLE>
really odd way. i almost reached across the internet to slap him. lol. yah i think also they say bigger injectors sometimes tend to give better off boost gas mileage because of how fast/slow they open in comparison to smaller ones. when i had the afc hack on my car running dsm 450's. i made it from miami to tampa with like a lil over quarter tank left. before when my car was stock, and i lived in tampa and used to go tampa to miami, i used to end up just about at E consistently.
Old Nov 10, 2004 | 02:14 PM
J337_UNIT's Avatar
OHH yes i think your right.. to me.. that does sound right now.
Old Nov 10, 2004 | 02:16 PM
Finland's Avatar
Just adding a turbo charger will definitely not increase fuel economy. Personally I didn't lose much either though. Maybe 1 to 2 mpg, depending how hard I drive.
I have heard of some creative tuning some people have done for off boost conditions that has netted better overall mpg.
Old Nov 10, 2004 | 02:20 PM
Marauder's Avatar
Default Re: Can turbocharging INCREASE fuel efficiency? (J337_UNIT)
Turbocharging increases Volumetric Efficiency
Old Nov 10, 2004 | 02:23 PM
sporkcrx's Avatar
Default Re: (syckturboITR)
On Gary and Randy's site (the ones that *i think* originated with the adaptor plates on hf manifolds) they both got 1-2mpg better than before the turbo. Of course not all variables are controlled (impossible for a car you drive everyday) but it just shows it will not kill gas milage.
I think one way someone put it (I have no idea if it holds true or not) is say you're accelerating up to the speed limit, before you would have to give it more throttle to get to the speed limit, at a decent rate. Well with the turbo, you would only press the throttle half the distance of that and it spools and gets you to that speed limit, at the same rate, but less throttle. But then you also have bigger injectors etc, so I have no ******* clue.
Old Nov 10, 2004 | 02:24 PM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">
u realize thats like 800 miles to the tank?</TD></TR></TABLE>
PM snoflake_EG and ask him......
from filling up to 3/4 tank , its about 187 miles to my house .
Old Nov 10, 2004 | 03:18 PM
Turbo E's Avatar
my results. basicly i got the same fuel economy as when i has a stock D16Z, now i have a B18C w/boost. i still get 500+Kms/tank
and i can actually pass people when i need to
Old Nov 10, 2004 | 05:25 PM
careawholelot's Avatar
i can back this up, me and him filled up at the same time in walnut creek ca, we had to drive back to lemoore ca which is about 200+- miles about 20 miles from lemoore i was on e, then mark calls me over to look at his gas guage it was still 3/4 full i couldn't believe it myself and he and snoflake eg when at it with each other on the freeway and my *** wasn't going over 4k rpms.
