Can i piece together a turbo with $1500
Can i boost my b16 with $1500 Im in the line of deciding between NA or FI.
Should i drop 1500 on cams pisons retainers or whatever and make 150 hp. Or is $1500 enough to start a Turbo set up. I really need some advice? |
Re: Can i piece together a turbo with $1500 (crxh22project)
if you do it on here you will be borderline...but it can be done.you just have to pick and choose wisely.
harv |
maybe you can find a used kit or something, but don't be cheap with it comes to fuel management
Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">maybe you can find a used kit or something, but don't be cheap with it comes to fuel management</TD></TR></TABLE>
that is correct also.....or your motor well you know the rest of the story. harv |
im in progress of boosting. i got my t3/t04 for only $700 but it didnt came with down pipe, exhaust flange, I/C pipe. ( i know its weird )
well its another $100 for the downpipe & labor. another $40 for the flange. $350 for injectors and FPR/G. so im guessing about $1250 so far. plus gas and food to pick up the parts. https://honda-tech.com/forums/images...s/emsmilep.gif i say go boost. i came from NA but im trying something new https://honda-tech.com/forums/images/smilies/emthup.gif |
naisbest where is your fuel management?
Re: (PrettyLude)
Yeah for EMS i'll run something like uber or crom someting cheap.
No Engine management + FI +t3h sucks. |
http://hondamarketplace.com/zerothread?id=1376019
1250 bucks, basically everything you need, just add fuel management |
Re: Can i piece together a turbo with $1500 (wantboost)
I just turbo'd my 91 integra (a.k.a. Cheap Slut) for about $300. It's my bucket car that I have fun in. The easiest way to cut costs is if you have the ability to fab up charge pipes, manifold, ect....
