can golden eagle hook this up?
Old Feb 5, 2008 | 03:22 PM
mangina's Avatar
Default can golden eagle hook this up?
#3 sleeve cracked 2.5 inches down.
[IMG][/IMG]
not bad for 200k miles
[IMG][/IMG]
thanks
Modified by mangina at 4:41 PM 2/5/2008
Old Feb 5, 2008 | 03:23 PM
blwn95civic's Avatar
Default Re: can golden eagle hook this up? (mangina)
Fix your pic
Old Feb 5, 2008 | 03:27 PM
mangina's Avatar
because they are closed right now.
maybe somebody had the same problem and got it fixed.
thanks
Old Feb 5, 2008 | 03:37 PM
Chiovnidca's Avatar
Default Re: (mangina)
You cracked a golden eagle sleeve???
Old Feb 5, 2008 | 03:41 PM
mangina's Avatar
no
I need to get sleeved
Old Feb 5, 2008 | 03:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mangina &raquo;</TD></TR><TR><TD CLASS="quote">no
I need to get sleeved</TD></TR></TABLE>
Yea, now I can see your pics.
Old Feb 5, 2008 | 05:49 PM
HiProfile's Avatar
I'm not sure how GE does their blocks, but given the amount of blocks they do, I'd guess they don't simply bore from top to bottom. It would make sense to save time and carbide to essentially cut the sleeves off near the base, like cutting a pipe from the inside.
As long as the crack doesn't go past the base of the water jacket, they should be able to use it as a core.
BTW Cracking nearly all the sleeves at once after @200k boosted miles isn't bad. Cracking multiple sleeves on an old block just shows some catastrophic part failure, or a crappy tune.
Old Feb 5, 2008 | 06:16 PM
Runnerdown's Avatar
Default Re: can golden eagle hook this up? (HiProfile)
just call them up when they open, will a few hours until you find out really matter?
Old Feb 6, 2008 | 07:10 AM
CerealKiller's Avatar
Looks like they can, but you (like it has been said), give them a call or might want to email your pics to them. Golden Eagle Mfg. sleeved
Old Feb 6, 2008 | 07:56 AM
mangina's Avatar
Thanks for your help
Ill give them a call
Old Feb 6, 2008 | 09:01 AM
Golden Eagle's Avatar
should be no problem
Old Feb 6, 2008 | 09:06 AM
mangina's Avatar
once I get it out
It will be on its way.
thanks GE
Mike_S
Apr 21, 2008 03:56 PM
Mr. K20addict
147
Mar 24, 2008 10:04 AM
specie
Nov 30, 2006 07:50 PM
prestoned
27
Dec 8, 2003 07:32 AM
11psiTurboSI
Nov 11, 2003 08:02 AM
