Can anyone please answer this question? Thanks
Old Nov 25, 2002 | 11:52 AM
AzianAvenger's Avatar
New User
Default Can anyone please answer this question? Thanks
I have Acura Integra LS 9.2:1 forged wiseco pistons in my stock sleeved GSR block. I also have the stock GSR head and stock head gasket.
The question is what is my compression?
Is it 9.2:1 or does my stock GSR head raise the compression to 9.5:1?
Thanks
-AzianAvenger
Old Nov 25, 2002 | 12:02 PM
Boostfed's Avatar
New User
Default Re: Can anyone please answer this question? Thanks (AzianAvenger)
Try this site out it may help.
http://www.c-speedracing.com/howto/c.../compcalc.html
Old Nov 25, 2002 | 12:04 PM
Boostfed's Avatar
New User
Default Re: Can anyone please answer this question? Thanks (Boostfed)
I calculated 9.555 with the info you provided me, if the deck or head have been milled could be slighlty different. HTH Also you will not truely know your compression ratio w/o cc'ing it, we have done a couple of motors and cc'ed them and they were quite a bit off what the manufacturer stated.
[Modified by Boostfed, 4:05 PM 11/25/2002]
Old Nov 25, 2002 | 12:12 PM
New User
MY block was decked .001.
What is the Bore and Stroke of a B18A/B (LS) in mm?
What is the Piston Displacement cc per piston for LS?
And what cc per cylinder is the LS pistons?
Thanks again for the help guys.
I am N/A right now and for some reason my GSR feels really slow...slower
than 9.55:1 compression...
Thanks Boostfed btw
-AzianAvenger
Old Nov 25, 2002 | 12:52 PM
Boostfed's Avatar
New User
Stroke is 87.2mm, everything is teher, you don't have to make any calculations, is is prefilled with bore and stroke and bore size for each prospective piston. Easy easy.
BOOSTEDgreeneg
Jan 27, 2006 02:05 PM
94lsboost
Apr 28, 2005 09:46 AM
B18 CYA
Apr 2, 2005 07:28 AM
B18 CYA
Apr 1, 2005 01:40 PM
super_slow
Feb 19, 2004 01:52 PM
