Cam and turbo question?
Old May 2, 2003 | 09:11 AM
1.8Tities's Avatar
Default Cam and turbo question?
Well, I'm running a d16a6 with crane cam stage 1, and I was kinda thinking if I will get shitty result(power) with my turblow. Your thoughts?
Here is the stock cam specs:
Stock Cam
Advertise Duration: Int=222 / Exh=224
Duration @ .50: Int=194 / Exh=196
Lobe Separation: 110
Gross lift: 333/362
My stage 1 crane cam:
Advertise Duration: Int=226 / Exh=228
Duration @ .50: Int=200 / Exh=202
Lobe Separation: 107
Gross lift: 384/376
Old May 2, 2003 | 09:46 AM
Ivan's Avatar
senior gold member
Default Re: Cam and turbo question? (4thGSi)
Someone help this foo....he needs it bad. Should we swap out his cam or leave it in?
Old May 3, 2003 | 05:15 AM
1.8Tities's Avatar
Default Re: Cam and turbo question? (Ivan)
Help a brotha out.
Old May 3, 2003 | 08:00 AM
JalopySiR's Avatar
Leave the cam in. It may make the low end a lil' more sluggish, but your top end will be rewarded greatly.
Old May 3, 2003 | 09:49 AM
boosted hybrid's Avatar
The duration specs are fairly close, but the higher lift profile of the cam will help out greatly with boost pressure.
titosek4
Aug 11, 2009 06:04 PM
dpine
Jan 23, 2009 03:05 PM
hondaboyB18C1
Feb 10, 2006 05:27 PM
hytec
Nov 25, 2005 08:55 PM
ITSTOCK
Jan 11, 2004 09:45 PM
