Built b16 turbo problem
I got a 82mm Dart sleeved b16 motor. Stock b16 head with itr cams. I'm running an AFI turbo kit AC ranhorn with a full 3 inch exhaust. Its got a Garrett T3/T04E 57 trim. 2 inch hotside piping and 2.5 cold side pipe. My question is, when it was tuned it did 280@10 psi and 375@15 psi. But anytime was went over 16psi we started losing power. I'm trying to figure out if its the small intercooler or the 2 inch hotside pipe. If anyone had any input please let me know.
Thanks alot Chris |
Re: Built b16 turbo problem
Originally Posted by BoostedEgHatchFl
(Post 43841757)
Thanks alot Chris |
I dout its the turbo. But that could be the problem
It's not the turbo. The turbo is good for 400-450 and somewhat over 20 psi. Did the car not make any more power or the gains per psi of boost weren't much? What's the full setup down to the last everything. Exhaust size turbine housing size. How much of the charge pipin is 2"
What brand/size intercooler? What were the IAT's at when you started dropped power?
Originally Posted by Turbo-LS
(Post 43843742)
Its a Garrett T3/TO4E 57 trim. Its a full AFI ram horn ac kit. Full 3 inch exhaust and dp. Its only 2 inch piping from the turbo to the ic. I believe its a .62 a/r exhaust housing. Anything over 16 psi it would start to lose power. |
Originally Posted by hybrid1990crx
(Post 43845825)
Sell it, it's FWD and therefore worthless.
Intake temps are higher than I'd lik to see that's for sure. Is the whole charge piping 2" or just the hotside? I run 2" just off the turbo for fit ent issues which is about 9 inches then go right to 2.5 the rest of the way. I believe with 2" your reaching or surpassing recomended Mach air speed inside the charge piping by running alot more boost. Try a larger hotside
Its 2 inch to the ic...... Maybe 2 feet of piping......
It should be ok but try larger. The intercooler is probably to small and those intake temps will reduce power production. Plus the ic maybe be restricting
I'm getting a bigger ic soon.
