BOV Question: I DID SEARCH
Old Apr 19, 2006 | 05:20 PM
Integra21's Avatar
Default BOV Question: I DID SEARCH
Hey everyone, i searched "adjusting bov" and read through all 13 results (archived and all ) and no one had the same issue, so.....
i have a greddy type-s bov and when i was adjusting it (maybe too much) the threaded stud along with the locking nut came off. now i can screw the stud in partially but it does not allow much, if ANY adjustability. it also seems as if it is just barely in there (like one or 2 threads)
Any ideas?
Integra21's Avatar
Default Re: BOV Question: I DID SEARCH (Integra21)
i can get pixtures if it would help but i dont think theyre necessary, unless my description blew.lol
Old Apr 19, 2006 | 06:40 PM
Soccerking3000's Avatar
did you strip the hole out?? the locking nut really isnt necessary, but if it is stripped drill it out and tap it for a larger bolt
edit: and yes get pictures those are always good
Old Apr 19, 2006 | 06:46 PM
Integra21's Avatar
Default Re: BOV Question: I DID SEARCH (Soccerking3000)
ill get some pics up tomorrow - im worried that it will not hold boost (12psi) when i get my set up back to 100%.
id rather not drill and tap - lol - ill prob just buy another one if thats the case
Old Apr 19, 2006 | 06:51 PM
all go teg's Avatar
i would try and take it apart, see how the valve looks on the underside. im not really that familiar with the type S but i have the type RS and its similar, then again i have never taken it apart just watch out for the spring in there so the top doesn't shoot off and poke out an eye
Old Apr 19, 2006 | 06:52 PM
komat's Avatar
Default Re: BOV Question: I DID SEARCH (all go teg)
jb weld the nut onto the top cover
Old Apr 19, 2006 | 08:20 PM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
Default Re: BOV Question: I DID SEARCH (komat)
If ur just gonna buy another bov then I have one forsale its a rfl bov welded in 2.5 charge pipe lmk thanks
Old Apr 20, 2006 | 03:19 AM
Finland's Avatar
Default Re: BOV Question: I DID SEARCH (spoon95eg)
I just repaired a guy's Greddy-S, he had the same problem.
I just drilled and tapped the hole for an 8mm bolt (go as fine as you can..more threads = more strength)
A common mistake that people make is that they don't loosen the locknut before adjusting, so the threads pull out.
It's not as pretty as it is functional
Old Apr 20, 2006 | 06:24 PM
Integra21's Avatar
Default Re: BOV Question: I DID SEARCH (Mr. Helsinki)
thanks for the pic - i just took some but looks like no need to post them.
im not sure what ill do.
any other makers (other than greddy) BOVs that fit on the greddy flange??
Old Apr 20, 2006 | 06:56 PM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">
any other makers (other than greddy) BOVs that fit on the greddy flange??</TD></TR></TABLE>
vortech
Old Apr 21, 2006 | 03:14 AM
MoonScryer's Avatar
Just oversize the bolt so an 8mm can fit, and do like above. Why spend a bunch when you only need to spend a little?
Old Apr 21, 2006 | 05:12 AM
Integra21's Avatar
Default Re: (MoonScryer)
im not sure if i want another bov though... ive been kicking around the idea of a new one also... not sure
any other brands use the same flange other than vortech?
Old Apr 21, 2006 | 05:29 AM
The Weather Man's Avatar
The raptor bov has the same flange.
Or if yo uwant to get a chea pone - you can get one from a skyline - has the same flange....uh, thats all i can think of off top of my dome.
Old Apr 21, 2006 | 10:20 AM
Integra21's Avatar
Default Re: (The Weather Man)
any more info on the chea pone? never heard of it
just weighing out my options now
crooklyn_outlaw
Oct 24, 2008 07:18 AM
NuclearB18B
Sep 16, 2003 12:38 PM
underpressure02
Sep 12, 2003 10:20 AM
boostedcoupe
Nov 21, 2002 10:24 AM
GruvyTune
Oct 27, 2001 07:33 PM
