bottom end done - time to build the head??? valvetrain
Old Jun 2, 2004 | 05:28 PM
dunkd's Avatar
Default bottom end done - time to build the head??? valvetrain
heres some pics of my valves, i think two are messed up?? https://honda-tech.com/zerothread?id=883762
bottom end is 2.0L 84mm GSR Darton sleeved, endyn 9:1 pistons, manley rods.
New cams isn't in my budget for this year. Should I upgrade my valvetrain? springs, retainers, valves, valve seals...?? Right now as it sits it's just stock GSR head. If iam not getting cams should i just wait off to upgrade the other stuff?
Old Jun 2, 2004 | 05:53 PM
lonnieboost's Avatar
Default Re: bottom end done - time to build the head??? valvetrain (dunkd)
You have the same exact block as I do except for the rods. You are going to be sooo happy
Old Jun 2, 2004 | 06:22 PM
dunkd's Avatar
i wont be happy until i get a it all slapped together! lol
Old Jun 2, 2004 | 06:30 PM
btleier's Avatar
Default Re: (dunkd)
I assume with that compression ratio that you are planning on going turbo. In that case I would ABSOLUTELY upgrade your valvetrain, with valves, springs, and retainers. There is really no need for aftermarket cams, I have a buddy making 400whp untuned on GSR cams, however if you wanna rev high, which you'll need if you're running a big turbo, valves, springs, and retainers, is a must.
Old Jun 2, 2004 | 06:35 PM
DaveF's Avatar
Default Re: (btleier)
Ed's racing heads
610 529 7028
pm " fkned " for more info.
Old Jun 2, 2004 | 06:52 PM
dunkd's Avatar
yes t3/60-1 turbo forgot to mention that.
Old Jun 2, 2004 | 07:17 PM
m R g S r's Avatar
Default Re: (dunkd)
I am in the process of building a short block. I also plan on keeping the head stock, boositng it, see what numbers I can get then I am going to pull off the head and rebuild it. Valves, springs, retainers, port and polish and maybe some type r cams. I think if your going to do it, you might as well hold off and do it all at once.
Old Jun 2, 2004 | 08:57 PM
btleier's Avatar
Default Re: (m R g S r)
I would do the valvetrain all at once except for cams. Waste of time IMO on a GSR
Dainteggy
Jul 16, 2012 03:03 PM
insaneconceptz
May 21, 2010 02:07 PM
ChaseIntegra
11
Jul 13, 2006 08:45 PM
ITRPNP
Jan 24, 2006 10:42 PM
