boosting my single cam.... have turbo ????
hey guys,
I have a couple of questions about the turbo Im going to use and cant find what Im looking for so here it goes.... first, I will be using a stock t25 with a .45 trim off of a 2gen mitsubishi eclipse. I will be using the stock internal wastegate and wastegate vacuum actuator. what is the stock boost level for this turbo?? I need to know what the stock psi is so my tuner can burn me a basemap chip. second, the oil feed line is threaded into the the main housing of the turbo. will I have to run an oil restictor for this particular turbo and if so, what size restrictor? thanks for any input!!! |
Re: boosting my single cam.... have turbo ????
really nobody???
Originally Posted by jdmracer12
(Post 41797291)
hey guys,
I have a couple of questions about the turbo Im going to use and cant find what Im looking for so here it goes.... first, I will be using a stock t25 with a .45 trim off of a 2gen mitsubishi eclipse. I will be using the stock internal wastegate and wastegate vacuum actuator. what is the stock boost level for this turbo?? I need to know what the stock psi is so my tuner can burn me a basemap chip. second, the oil feed line is threaded into the the main housing of the turbo. will I have to run an oil restictor for this particular turbo and if so, what size restrictor? thanks for any input!!! #2... not sure... somebody can probably chime in though.. |
