boosting my single cam.... have turbo ????
hey guys,
I have a couple of questions about the turbo Im going to use and cant find what Im looking for so here it goes....
first, I will be using a stock t25 with a .45 trim off of a 2gen mitsubishi eclipse. I will be using the stock internal wastegate and wastegate vacuum actuator. what is the stock boost level for this turbo?? I need to know what the stock psi is so my tuner can burn me a basemap chip.
second, the oil feed line is threaded into the the main housing of the turbo. will I have to run an oil restictor for this particular turbo and if so, what size restrictor?
thanks for any input!!!
Re: boosting my single cam.... have turbo ????
hey guys,
#2... not sure... somebody can probably chime in though..
civic2nr9177
04-11-2004 06:25 PM
