Boosted CR-V Questions
Old Jun 28, 2007 | 08:17 AM
theruckus's Avatar
Default Boosted CR-V Questions
I've never looked at a CR-V drivetrain and I have a couple questions. First, is the CR-V's (97-01) 4wd system strong enough to handle boost, maybe in the 220-250whp range? Second, since I'm guessing you can't use a different B series tranny and retain the 4wd, is it possible to swap out the gears to get better ratios?
Also, does the CR-V tranny/transfer case bolt up to any other B series blocks? Is there anything you can do to beef up the rear differential?
Old Jun 28, 2007 | 02:21 PM
theruckus's Avatar
Default Re: Boosted CR-V Questions (theruckus)
Nobody?
Old Jun 28, 2007 | 07:11 PM
jelcivic's Avatar
I've seen some guys take an Integra and use the dif and some other CR-v parts and made it into RWD. They keep the motor N/A and were using it in drifting events. I don't know what parts are needed for what you are doing but I think it would be fun if it works out. good luck.
Old Jun 28, 2007 | 11:54 PM
ImportHatch's Avatar
Default Re: Boosted CR-V Questions (jelcivic)
Not really sure why people that actually try these awd swaps actually use the complete crv drivetrain. Why not just use an irs out of an rx7. Those crv drivetrains aren't really the toughest.
Yager-
Old Jun 29, 2007 | 12:09 AM
theruckus's Avatar
I'm talking about in an actual Honda CR-V, not the CR-V engine and tranny in a different car.
Old Jun 29, 2007 | 12:26 AM
Default Re: (theruckus)
Oh I'm sure it would hold the power, its the launches that would kill it.
EDLOVA23
12
Feb 15, 2014 06:07 AM
TXGrunt
13
Dec 13, 2007 11:57 AM
theruckus
Jun 28, 2007 08:28 AM
spog
Oct 17, 2004 03:36 AM
