best turbo for a b16?
im going to boost my b16 (or maybe a b18b) and i was wondering what turbos every1 uses? i will be putting in a crx. i can get a 14b really cheap, and i only want to run 7-8 psi.
Best turbo?
What kind of power goals do you want?
If you want 300hp, get a t3/t4 that's "best" for your application .. if you want 500+ hp, get something like an SC61 which is "best" for that application.
im looking to boost the stock motor at around 7-8 psi, probly like 215 hp? would a t3e 2 small? ill probly end up going with a t3/t4, but im tryin to keep it low cost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markaria »</TD></TR><TR><TD CLASS="quote">I have a b16 w/ ctr cams I put down 216 hp at 7psi with t3/t4 with a 48 exh/60 compressor turbo.
I am happy with the results.
good luck</TD></TR></TABLE>
is that at the wheels?
omg 7 years ago...
