best tool to cut off bumper
Old Apr 6, 2004 | 07:29 PM
skellator_thoj's Avatar
Default best tool to cut off bumper
what tool should i use to cut my ww front bumper (urethane) so it'll fit my fmic?? any advice would really help.
Old Apr 6, 2004 | 07:33 PM
d16y8turbo's Avatar
Default Re: best tool to cut off bumper (skellator_thoj)
i used a dremel tool, but the plastic cuts very easily. you can use just about anything. the dremel did a great job though
Old Apr 6, 2004 | 07:36 PM
showtymers619's Avatar
* B A N N E D *
Default Re: best tool to cut off bumper (d16y8turbo)
box cutter
Old Apr 6, 2004 | 07:38 PM
redboost10's Avatar
Default Re: best tool to cut off bumper (ShowTymers619)
4" cutting wheel is pretty easy to use and keep it straight. dremel works great too
Old Apr 6, 2004 | 07:39 PM
box cutter?? what exactly is that??
Old Apr 6, 2004 | 07:43 PM
IN VTEC's Avatar
Razor blade that slides in and out of a grip.
Old Apr 6, 2004 | 07:52 PM
Default Re: best tool to cut off bumper (IN VTEC)
can someone post pics of their front bumper cut to fit a fmic
Old Apr 6, 2004 | 07:53 PM
Dr Pooface's Avatar
Boxcutter:
Old Apr 6, 2004 | 07:58 PM
IN VTEC's Avatar
Default Re: best tool to cut off bumper (Dr Pooface)
Only the ones we have in the garage aren't so pretty.
I'll cut j00 mang.
Old Apr 6, 2004 | 08:05 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Boxcutter:
those but the bigger version that uses larger blades
Old Apr 6, 2004 | 08:08 PM
JdM_y0's Avatar
use that, fast and easy. thats 1 pimp *** kit
Old Apr 6, 2004 | 08:18 PM
FlaN.'s Avatar
dremel definately! unless you want a hack job. those who use box cutters, post some pics up
Old Apr 6, 2004 | 08:30 PM
lazerus's Avatar
Default Re: (FlaN.)
box cutters cut eurathane clean.
Old Apr 6, 2004 | 08:32 PM
FlaN.'s Avatar
Default Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">box cutters cut eurathane clean.</TD></TR></TABLE>
hmmm, do they normally cut all the way through?
Old Apr 6, 2004 | 08:37 PM
calib17a's Avatar
Default Re: (FlaN.)
Dremels or any high speed cutter will melt the urathane as you cut then heat will fuse them back together after the cut. I used a Utility knife but take use a sharpie to mark your line on the inside of the bumper then take your time in cutting. You can also use a small hand held saw with medium size to large teeth.
Old Apr 6, 2004 | 08:42 PM
5thgencivic's Avatar
Default Re: (calib17a)
I busted out the 4" grinder and went at mine Globs everywhere, but there was no way I was cutting all the stuff with a knife or even snips... Follow up with a file and sandpaper and it's good to go
Old Apr 6, 2004 | 08:47 PM
RenoRacing's Avatar
Default Re: (5thgencivic)
Air powered body saws are really nice too. like mini sawz-all's but air powered rather than electric. i used one to install some dog doors the other day....
Old Apr 6, 2004 | 09:37 PM
WuShu's Avatar
New User
Default Re: (RenoRacing)
like someone said, soon as you cut urethane itll melt and leave a mess. Just get some yard shears, or metal shears, they work great and give you lots of control over your cut.
Old Apr 6, 2004 | 10:46 PM
twkdCD595's Avatar
Default Re: (WuShu)
sawzall (prolly not spelled right but whatever).
Old Apr 6, 2004 | 10:56 PM
roydogg's Avatar
Default Re: (twkdCD595)
Hacksaw it, and use some elbow grease too
Old Apr 6, 2004 | 11:01 PM
SiRkid's Avatar
Default Re: (roydogg)
sawzall man..that **** cuts anything
Old Apr 6, 2004 | 11:55 PM
Group Tenacity's Avatar
I used a jig saw to cut my bumper....
Old Apr 7, 2004 | 12:09 AM
lazerus's Avatar
Default Re: (FlaN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlaN. &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm, do they normally cut all the way through?</TD></TR></TABLE>
Yes, i've cut many a urathane with a good sharp box Cutter, just like in the picture there!
cuts it like cold butter
Old Apr 7, 2004 | 04:25 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">sawzall man..that **** cuts anything </TD></TR></TABLE>
sawzall with a STAINLESS STEEL cutting bit!!!
it's got metallic compound on the blade instead of TEETH! NOOOO chance of it hanging up and cracking the urethane bumper...
Old Apr 7, 2004 | 04:27 AM
PM-Performance's Avatar
Default Re: (stackz)
I used a saw zaw. the dremel tends to melt plastic. i used the dremel a little to clean up the cut a little nicer though
