before going to tune my car...
Old Jun 7, 2007 | 11:45 AM
civic_saints1's Avatar
Default before going to tune my car...
So what all do I have to make sure I have in order to tune my vehicle?
Old Jun 7, 2007 | 12:04 PM
dsnyder305's Avatar
Default Re: before going to tune my car... (civic_saints1)
Does it run? I'm not trying to be a dick, but if it starts and runs, you should be good. Have the guys at the shop check it out for you before they tune it, they will be able to help you better. What have you done to your car?
Old Jun 7, 2007 | 12:05 PM
92redhatch's Avatar
No check engine lights! no leaks. healthy compression numbers.
thats what i check before i tune.
Old Jun 7, 2007 | 12:10 PM
SC61HB's Avatar
Replace cap and rotor, check compression/leakdown.
Old Jun 7, 2007 | 01:05 PM
VtecCarHauler's Avatar
Default Re: before going to tune my car... (SC61HB)
yeah everything that they said. Unfortunately you will find out if anything is wrong on the dyno which sucks. A street tune with a wideband would be good before going to the dyno. Many ppl don't agree with me but it helped me solve my problem by myself. I took me 5 tries at the dyno before I figured out my problem and I had everyone helping me, from guys with tech engineering degrees to guys with 9 sec Civics. Turned out my problem was a $5 part (stock fuel damper on the fuel rail ). Fixing a problem in front of your house with no presure on you is much easier than fixing it on the dyno with the tuner, friends, and strangers, watching you (trust me). You don't really have to fine tune it on the street just make sure everything is working right under a little load.
inspyral's Avatar
Make sure everything is in good working order. Have a couple sets of spark plugs. Make sure all your hoseclamps and couplers are tight. Make sure your fuel pressure and base timing are what they should be. Bring some tools with you in case you have to reconnect couplers, etc while tuning. If you have adjustable cam gears, make sure they're accessible(cut valvecover, removed/cut timing cover, etc) and you have the right tools to adjust them. Check with your tuner and see if they have a specific checklist of things you should go over prior to the tune.
Old Jun 7, 2007 | 02:00 PM
Wow you guys are really helping me out, I really appreciate this guys!!And how do I check my compression numbers?
Old Jun 8, 2007 | 07:35 AM
sp00led's Avatar
Default Re: (civic_saints1)
you can buy a compression tester at most local autopart places. Do a search and you will find some threads on how to properly use one.
Just make sure you have the basics covered. Top off the oil, bring an extra set of plugs (correct heat range), and make sure you have the key to your wheels or any other misc items. You never know what is going to break or happen when your beating on the ride.
Old Jun 8, 2007 | 09:56 AM
Strokin4dr's Avatar
Default Re: (sp00led)
I would check base timing and make sure you have NO boost leaks. Not just by looking at the pipes, make a tester and charge the system. You will find leaks you never knew you had.
N.Y.C.E.
Jun 22, 2010 07:40 PM
goforbroke
46
Feb 18, 2004 07:28 PM
goforbroke
Oct 16, 2003 04:30 PM
fso_BamBam
Mar 23, 2002 09:42 PM
