Baro Sensor Problems "The Only Code!" CRX 1988 Hf
Old Jan 27, 2005 | 06:15 PM
THE FUCATYPR HATCH's Avatar
Default Baro Sensor Problems "The Only Code!" CRX 1988 Hf
I have replaced the sensor in my passenger side kick panel but the light still comes on and the code is still there. Even after I kept the computer out over night. The code comes on even befor inital start up. This ones got me beat?
Help?
Old Jan 27, 2005 | 06:27 PM
PyroProblem's Avatar
Default Re: Baro Sensor Problems "The Only Code!" CRX 1988 Hf (THE FUCATYPR HATCH)
If Im not mistaken,the baro sensor is integrated inside the ecu... Only way to fix it is a new ECU...
Hope Im wrong though>!
Old Jan 27, 2005 | 06:32 PM
crx12's Avatar
Default Re: Baro Sensor Problems "The Only Code!" CRX 1988 Hf (PyroProblem)
Same problem here, running ZDYNE B16 one wire. I can't ever get rid of it, then again its never hurt how the car runs so I just leave it. I guess you could pull the bulb
Old Jan 27, 2005 | 07:10 PM
Default Re: Baro Sensor Problems "The Only Code!" CRX 1988 Hf (crx12)
It just gives me a pretty big kick that no one on the internet knows how to fix this problem.
Old Jan 27, 2005 | 08:04 PM
xenocron's Avatar
If you were running TurboEdit you could disable just that code...it doesnt affect how the car runs so...
Old Jan 27, 2005 | 09:01 PM
Default Re: Baro Sensor Problems "The Only Code!" CRX 1988 Hf (xenocron)
So what do you do chip your ecu and have a chip burner avalible? No realtime?
Old Jan 27, 2005 | 10:13 PM
xenocron's Avatar
You could disable the code in the BIN file.
Yes you would need a chipped OBD0 ECU and a burner to burn the chips.
RTP is so-so right now...soon to be resolved hopefully.
THE FUCATYPR HATCH
Jan 27, 2005 09:17 PM
pounder89
Apr 29, 2004 08:19 PM
Prelude MIke
Apr 22, 2004 07:34 PM
johnzm
Sep 24, 2003 03:15 PM
