balancing crankshaft
Old Feb 16, 2006 | 03:39 PM
hondaaccord94's Avatar
Default balancing crankshaft
how much do machine shops charge to balance your crankshaft?if im using manley rods and cp pistons theres no need to balance them because they come out the factory balanced perfectly correct?
Old Feb 16, 2006 | 04:20 PM
DelSolDon's Avatar
Default Re: balancing crankshaft (hondaaccord94)
my shop charged me $145 to balance the entire rotating assembly. i used eagle rods, wiseco pistons, stock crank. some people will tell you that balancing is not needed on an inline engine, but i figured for $145, why not?
Old Feb 16, 2006 | 04:58 PM
D@nnY's Avatar
Default Re: balancing crankshaft (DelSolDon)
benson charges 150 to polish and balance the crank ..pm earl....
A little bit of inblanace at 9 k rpm is huge
Old Feb 16, 2006 | 05:31 PM
Default Re: balancing crankshaft (D@nnY)
somebody is trying to charge me 300 to balance and polish the crank isnt that a rip off.
Old Feb 16, 2006 | 05:36 PM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaaccord94 &raquo;</TD></TR><TR><TD CLASS="quote">somebody is trying to charge me 300 to balance and polish the crank isnt that a rip off.</TD></TR></TABLE>
Yes... OEM cranks are usually quite close... and its not multiple hours of labor to do....
Old Feb 16, 2006 | 06:23 PM
paulzy's Avatar
I got my whole rotating assembly done for $175
that included crank, rods, pistons, clutch, and flywheel. I would have balanced the crank pulley too but I'm already running an aftermarket damper
EK FLY
May 22, 2005 09:14 PM
euclid
10
Dec 21, 2004 05:46 PM
choiboiracing
Apr 8, 2004 09:44 AM
TURBO B
Oct 23, 2003 04:13 AM
NightHawkC5
Mar 4, 2003 06:56 AM
