bad o2 sensor??????
Old Jul 4, 2003 | 09:58 AM
arjusmc's Avatar
Default bad o2 sensor??????
well after a very long wait, i am proud to say that i have a turbo integra. the bad news is that i believe i have a bad 02 sensor. first off here is my setup.
95 intgra ls, 135000
jdm b18b 35000
dms 440
safc
t3 off of a thunderbird
saab intercooler
drag mani and dp
deltagate(i know i know, but i don't think its the problem)
i'm getting bad gas milage, i did the blue wire mod and its reading at 1.4-4.5v. and the idle is a little off. i've been turbo for about 100 miles. sounds like a bad o2 sensor. i wish the parts stores were open today. what do you guys think.
Old Jul 4, 2003 | 10:04 AM
grndcont's Avatar
check the output voltage of the primary o2, with the car running you should have between .8~2.5V on the white wire, you can check it at the ecu, or at the sensor.
Old Jul 4, 2003 | 11:22 AM
arjusmc's Avatar
Default Re: (grndcont)
can i hook up the blue wire of the safc to that or just use a voltmeter
Old Jul 4, 2003 | 12:29 PM
b18bturbo's Avatar
Default Re: (arjusmc)
just use the volt meter to test the sensor first it sucks when you troubleshooting sensors
Old Jul 4, 2003 | 03:51 PM
grndcont's Avatar
correct, but the afc could be the problum itself, first mesure it at the o2, and then at any taps you have off of it.
4tika4
Jul 25, 2009 05:23 AM
powerdbygarrett
Jun 28, 2008 07:30 AM
LsTurbo91
Oct 8, 2001 09:20 PM
