back from the dyno, car is not making power HELP !!
after a long painful build finally i got the car tuned after having misfiring problem for ages
and i still got dissapointed with the final power figure
its only making 335whp @ 15psi
b18c
81.5mm 9:1 JE pistons
Eagle Rods
JG manifold
70mm TB
M&W pro 10 ignition
sc61 ---- > S housing with .63 a/r turbine housing and P-trim wheel
so pissed off
b18c
Eagle Rods
JG manifold
70mm TB
M&W pro 10 ignition
so pissed off
what are plugs gapped to? did you check for boost leaks? valves adjusted correctly? Do a leakdown lately?.... start there atleast
what manifold (log, short runner, topmount)? what turbo? a properly spec'ed turbo kit can make a world of difference.
if you had a rev-hard kit, i'd say you on the money. if your running full-race then i'd say your way low.
we assumed the misfiring was caused by an old tired dizzy cap and rotor ( they looked bad anyway )
so to save me from more headache i just told him to install m&w pro10 + crane coil, well that fixed the misfiring
my turbo setup is completely custom, heres my full setup:
Eagle Rods
Darton solid sleeves
SuperTech dual valve springs + retainers
ITR cams
Adj cam gears
JG manifold
70mm TB
SC61 turbo S housing + P-trim wheel in .63 a/r housing
custom high mount turbo manifold
880cc precision injectors + walbro pump
it was dynoed on a rolling dyno type ( dyno dynamics ?? )
car seems going really hard it just the final power figure really really dissapointed me
Eagle Rods
ITR cams
Adj cam gears
JG manifold
70mm TB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyber ITR »</TD></TR><TR><TD CLASS="quote">forgot to mention plugs are NGK platinum heat range 8, not quite sure about the gap tho</TD></TR></TABLE>
OMG. get those POS plugs out of your engine. NGK V-Power 7's (copper core) .025gap pn: 4091 i believe. and their only $2ea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">what are plugs gapped to? did you check for boost leaks? valves adjusted correctly? Do a leakdown lately?.... start there atleast</TD></TR></TABLE>
im going to have to side with wade on this one...
valves adjusted correctly ?
how old are your injectors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng »</TD></TR><TR><TD CLASS="quote">
OMG. get those POS plugs out of your engine. NGK V-Power 7's (copper core) .025gap pn: 4091 i believe. and their only $2ea. </TD></TR></TABLE>
never run platinum plugs either.....
I would take it to the track. Obviously you were expecting a strong 11 sec. car if 335whp was depressing. Run it man, you'll feel alot better if you hit your goal on the track. And personally, I'd say it's more braggin' rights to have super times with such low dyno #'s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyber ITR »</TD></TR><TR><TD CLASS="quote">after a long painful build finally i got the car tuned after having misfiring problem for ages
b18c
Eagle Rods
JG manifold
70mm TB
M&W pro 10 ignition
so pissed off
If you would, post up the dyno..
Run someone w/a car you think would be close..see what happens...??
But I do think for the mods the #'s are low, but track and mph tell a different story..
b18c
Eagle Rods
JG manifold
70mm TB
M&W pro 10 ignition
so pissed off
</TD></TR></TABLE>If you would, post up the dyno..
denso iridum are fragile.. dont run em... in the event that you do get a little detonation the insulator will break and trash stuff.
i run ngk iridum in everything, something making over 300 on pump gas id run an 8 heat range.
I thought irridium was mainly for plug life? One reason I ask is because all the plug info I've seen leads to that, and my friend's IS300 only had to change out the oem iridium plugs at 45k.
