b20b with turbo. Help guys??
Old Feb 9, 2002 | 04:06 AM
b20b's Avatar
New User
Default b20b with turbo. Help guys??
Ok I've got the b20b with Gsr head setup. I am going to Turbo it this sunday. What i'm curious and need to know is the oil line is already tapped into from the rear of the block for the head. Can I "T" off of that and run the turbine oil from there? Will there be enough oil pressure to provide sufficient oil to the head and the turbine? If not, where should I tap the oil for the turbine. The oil port that is blocked off from the head to block is not providing to the head, and in turn the pressure is redirected from the rear through the line. So theoretically speaking, it would be the same even if I just tapped off that line.(I hope) Somebody correct me if I'm wrong. If all else fails, I will just have to install the turbo and then do an oil pressure test after I'm done. But with that being, I don't want to have to do the whole install and then find out my head is starving or my turbine is starving. TIA!
Old Feb 9, 2002 | 07:03 AM
Tomakit's Avatar
Default Re: b20b with turbo. Help guys?? (b20b)
Most people like to "T" off of the stock oil pressure sensor unit on the back of the block.
Tom
Old Feb 9, 2002 | 09:52 AM
b20b's Avatar
New User
Default Re: b20b with turbo. Help guys?? (Tomakit)
Tom
Yeah, but I have already used that for the oil sent to the head. Is it ok to tap another line to the turbo from there?
Old Feb 10, 2002 | 11:44 PM
Ri5e's Avatar
give me your block and i'll find out, hehe.
Old Feb 11, 2002 | 05:31 AM
1's Avatar
Default Re: b20b with turbo. Help guys?? (BG Boost)
I'll take a pic when I get home and show you where I tapped the oil line to the head. I teed the sending unit to feed the turbo.
O16581724 5 2 5
Dec 25, 2005 08:10 PM
sirwags
Jul 31, 2005 07:13 PM
fastludeh22
Feb 7, 2003 03:44 PM
b20b
Feb 11, 2002 07:18 AM
b20b
Feb 9, 2002 04:05 AM
