b20b bore 2.2 or 2.3
Old Jun 3, 2004 | 11:28 AM
weraider30's Avatar
Default b20b bore 2.2 or 2.3
in the process of my first build, will be working with darton sleeved b20b block with je 9:1 pistons w/ eagle rods w/ b16 head. what is the mm size of these bores (2.2, 2.3)? also if you have any experience with either of these setups please feel free to share. (IE: streetable, drivability, reliability, etc....) please post
Old Jun 3, 2004 | 12:01 PM
Kataku2K3's Avatar
Default Re: b20b bore 2.2 or 2.3 (weraider30)
You will not get anywhere close to that especially with an FI motor if you're sticking to the stock crank. Earl posted up pics of an 86mm B16A FI block awhile back and that's the biggest I've ever seen. Trust me, there is no reason to go that big with an FI motor. Our B series FI motors never go above 84.50mm which with a B18C crank sets us right under 2.0L. Even if you had your motor was sleeved to 86mm you'd still only be at ~2.07L. If you're really looking for that displacement tho I hate the H series motors maybe that's what you should look into. Just my $0.02.
Old Jun 3, 2004 | 12:41 PM
weraider30's Avatar
Default Re: b20b bore 2.2 or 2.3 (Kataku2K3)
a performance shop nearby just did a b20b bored to a 2.3, and they said you could go to a 2.4 but with little room for error. but i am for sure going with atleast a 2.2, but i have heard of alot of 2.2s, but not as many 2.3s. just wanted to have others opinions before i did anything.
Old Jun 3, 2004 | 12:48 PM
SOUNDEFFECTS's Avatar
Not possible un less you stroke the B20 to get it to 2.3 or 2.4. Sorry there buddy, that shop is full of **** unless its stroked.
hoggy's Avatar
Listen to what the man above said. The larger you bore the less material between cylinders. If you leave the motor stock bore its stronger and you can run more boost and make more power that way.
Old Jun 3, 2004 | 08:04 PM
weraider30's Avatar
Default Re: b20b bore 2.2 or 2.3 (hoggy)
it was stroked also, but i know one thing for sure and that it was a 2.3 b20, and it was made to handle up to 55lbs of boost. if thats not enough boost and strong enough, then i don't know what is.
Old Jun 3, 2004 | 08:18 PM
Kataku2K3's Avatar
That's nice, 55lbs. eh? Is this a race motor? Should be good for ~1200whp Deckplated? We would also need that stroke in order to calc. the bore.
Old Jun 3, 2004 | 10:33 PM
Danger's Avatar
lol wtf ? would love to see a pic of those sleeves !
Old Jun 3, 2004 | 11:02 PM
BoredNStroked's Avatar
Default Re: b20b bore 2.2 or 2.3 (JonnyDanger)
They are ten foot thick concrete man....
Old Jun 3, 2004 | 11:33 PM
ndogg's Avatar
Default Re: b20b bore 2.2 or 2.3 (BoredNStroked)
i think you should just get a b16 and bore it to like 110mm and make it run like 75 psi using a terminator t1000 turbo. i bet that shop would hook you up.
Old Jun 4, 2004 | 05:05 AM
Kataku2K3's Avatar
Default Re: b20b bore 2.2 or 2.3 (ndogg)
That would do it, 2.94L with a single cylinder
Old Jun 4, 2004 | 07:34 AM
FBPninetynineEM1's Avatar
i think with the b20 the biggest you can bore it to is like, 2.26 and run it safley... the bore and stroke is, 87 mm for the bore and 95 mm for the stroke. crower makes a kit for this and yea tahts a big motor for a honda.
Old Jun 4, 2004 | 08:02 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">If you're really looking for that displacement tho I hate the H series motors maybe that's what you should look into. Just my $0.02. </TD></TR></TABLE>
What's wrong with the H22?
Old Jun 4, 2004 | 08:31 AM
Kataku2K3's Avatar
Default Re: b20b bore 2.2 or 2.3 (Finest)
We've had this debate a 1000 times, I just don't like it's overall design or how it looks and sits in an engine bay. B series
Old Jun 4, 2004 | 10:49 AM
weraider30's Avatar
thanks to those of you who are being serious, and no thanks to the ones making useless comments.
Old Jun 5, 2004 | 03:50 AM
Hard to be serious when we read the horse **** you post.
Old Jun 5, 2004 | 06:04 AM
weraider30's Avatar
what is horse ****?
Old Jun 5, 2004 | 06:08 AM
weraider30's Avatar
when using this site, if there is something in dont' quite understand or know, then i thought this was the place to learn or ask. i am sure at some time your weren't the genius of the honda world and someone came along and helped you out a little. so please, if you can't be serious then don't post.
Old Jun 5, 2004 | 09:33 AM
weraider30's Avatar
you guys can talk all you want, but if you want to see the engine, its sittin at pressurized motorsports (aka ballistic speed works) in bowling green, ky 42101.
Old Jun 5, 2004 | 09:51 AM
Kataku2K3's Avatar
I don't doubt the displacement of the motor if it's got an aftermarket crank but like I said before, we do need that to determine the bore you would need to do the same. It has a deckplate, correct? Find some specs on the motor if you can, pics would also be nice. I just don't see why you're looking for this displacement when you can make 600whp+ with ~2.0L street motor that already will give you traction problems up the ***.
Old Jun 5, 2004 | 02:40 PM
Adam....What kind of traction can be expected "up the ***"?
Old Jun 5, 2004 | 03:26 PM
mos's Avatar
mos
Even with an aftermarket 95mm stroker crank you can't get to 2.3 with a B series motor. With an 86mm bore thats 2.21 liters. Unless your cylinders look like an audi symbol...
You would need a kustom 104mm stroke crank to get to 2.4 Liters with an 86mm bore... and what would be the point? Like the guy said people make over 600 horsees on less than 2 Liters.
Ask this shop 'guy' where he got his crank. I'm curious.
It does sound rather hard to believe.
Old Jun 5, 2004 | 07:25 PM
dfoxengr's Avatar
Default Re: b20b bore 2.2 or 2.3 (mos)
i just sold my 86mmx95mm NA motor today.
biggest id ever run on a B would be 87x100.
and thatd be 2377.9 CC. huge....
def. not for turbo.
Old Jun 5, 2004 | 08:56 PM
weraider30's Avatar
Default Re: b20b bore 2.2 or 2.3 (hybridvteceg)
i will try to get the specs soon
Old Jun 7, 2004 | 11:27 AM
weraider30's Avatar
are you guys arguing the fact that this can't be done w/o being sleeved?
