b18c1 block question
Old Feb 10, 2004 | 03:57 PM
redboost10's Avatar
Default b18c1 block question
i have a b16a2 block and im planning on getting some 84-85mm sleeves. now if i come across a b18c1 block would it be worth it to get the b18 block and put 84-85mm sleeves in it and then put my b16 head on teh b18c block? how much of a difference is it between the two blocks with the same size sleeves? but i am gonna stay with the b16 head since it flows better than the b18c head
Old Feb 10, 2004 | 03:59 PM
Irishweird00's Avatar
Banned
Default Re: b18c1 block question (tgh99si)
well instead of having a 1.8L, you would net a 2.0L setup, that is built...
Depends on what your setup is... and what your plans are...
if the motor is out.. or not... ex.. ex.. ex....
search is key...
If your boosting alot... I wouldnt go over 83mm bore... and since you have a Si... judging from your name that is... Id pick up a b18 block and sleeve it to 83mm.....
Old Feb 10, 2004 | 05:03 PM
redboost10's Avatar
Default Re: b18c1 block question (Irishweird00)
what do you guys think about a b16a2 head on a b18c1 block? i havent read about that set up on here and i did search
Old Feb 10, 2004 | 05:24 PM
Kataku2K3's Avatar
The head choice is all up to you... We really run either but more commonly the P72... Most flow charts will show you that the P72 cylinder head flows better up top sacrificing a little midrange where as the PR3 does better midrange but loses up top... You know me, I'm all for the B18C... The the same compression, etc. the GSR will support a bigger turbo and is capable of more output than the B16A... Just my $0.02 again
Old Feb 10, 2004 | 05:27 PM
redboost10's Avatar
Default Re: b18c1 block question (Kataku2K3)
haha, i know you gz guys and the b18c. ill be keeping a look out for a b18c block. its just ive been told that the b16 head flows better than the b18c head so thats why i asked
Old Feb 10, 2004 | 05:29 PM
TurboJesse
Guest
Posts: n/a
how much power do you need? Keep the b16a, you can easily make alot more power than you would ever need...
Old Feb 10, 2004 | 06:37 PM
XSIintegra's Avatar
Default Re: b18c1 block question (Mpir3)
If your going to sleeve anything, get the b18 block. Thats my current build up right now. B18C1 bottom end w/ a ported B16 Head = Type-R set up minus pistons and cams. Should be a excellent set up sleeved to 83mm
Old Feb 10, 2004 | 06:56 PM
grndcont's Avatar
b18 has a main bearing girdle, and i think the water pump is different.
Old Feb 10, 2004 | 07:06 PM
Kataku2K3's Avatar
Default Re: (grndcont)
VTEC water pumps are all the same... No biggie tho...
Old Feb 10, 2004 | 08:55 PM
XSIintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grndcont &raquo;</TD></TR><TR><TD CLASS="quote">b18 has a main bearing girdle, and i think the water pump is different.</TD></TR></TABLE>
I was under the impression that b16's had main girdles also...at least I thought so.
Old Feb 10, 2004 | 09:32 PM
Kataku2K3's Avatar
Default Re: (XSIintegra)
Yea it's actually only the B18C/1/5 out of the B series motors...
Old Feb 11, 2004 | 04:13 PM
redboost10's Avatar
Default Re: (Kataku2K3)
i might be able to get my hands on a b18c5 block, how would this go with my b16 tranny, and my b16 head for fi set up, i would get 84mm sleeves, rods, and pistons. is the stroke the same as a gsr?
Old Feb 11, 2004 | 04:49 PM
aka010010
Guest
Posts: n/a
dont get a b16 tranny. get a gsr or type r tranny and maybe a lsd if u got cash.
as for the gsr block and si head...great combo!!! :thumb:
i would say, in my mind its the perfect combo! i think its more reliable then ls/vtec
Old Feb 11, 2004 | 04:52 PM
redboost10's Avatar
Default Re: (aka010010)
well i already have a b16 tranny with a quaife. so the itr block with the b16 head is just like the gsr block and b16 head? thats what i wasnt sure of
Old Feb 11, 2004 | 05:05 PM
Banned
Default Re: (tgh99si)
They are basically the same block..... the internals are what seperate them....
Old Feb 11, 2004 | 05:07 PM
redboost10's Avatar
Default Re: (Irishweird00)
ok i know about the pistons and rods, but is the stroke the same?
Old Feb 11, 2004 | 06:07 PM
redboost10's Avatar
the block i found and am interested in is a jdm itr block, is there a difference between that and a regular itr block?
Old Feb 11, 2004 | 06:16 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">the block i found and am interested in is a jdm itr block, is there a difference between that and a regular itr block?</TD></TR></TABLE>
Same stroke, same displacement.... all B18 vtec blocks have the same displacement.....
just crank/pistons/rods vary from motor to motor.... There is not much difference between the "JDM" and "USDM" ITR blocks, except for slight compression differences.
Old Feb 11, 2004 | 06:18 PM
redboost10's Avatar
alright i couldnt find the jdm specs so i didnt know, thanks man, the comp dosnt matter since ill be putting other pistons in there. thank you
Old Feb 11, 2004 | 07:31 PM
redboost10's Avatar
is it true the itr crankshaft weighs more than a gsr? if so is this a disadvantage for fi?
Old Feb 11, 2004 | 07:36 PM
Kataku2K3's Avatar
Yea, the ITR crank does weigh a little more than the GSR as it has larger factory counter balances... You're not going to notice any difference either way so it really doesn't matter... Just have your entire rotational assembly rebalanced once you get your rods, etc and you'll be set...
Modified by Kataku2K3 at 8:58 PM 2/11/2004
Old Feb 11, 2004 | 07:37 PM
redboost10's Avatar
hey adam, thanks man
carbonn
Mar 21, 2009 03:12 PM
jdmbubbleback
May 8, 2004 10:24 AM
Nikos
11
Jul 5, 2003 02:44 PM
shingles
Mar 18, 2003 02:23 PM
