b16T Ramhorn Overheating?
Ive checked for air bubbles, not a blown head gasket, and the fan is on. i think the reason is lack of airflow though the engine bay, and the manifold runs right behind and is only about 1/2 inch away from the radiator.
It only happens with the bumper on, hot days, while over 2k rpms. Things I've tried to fix the issue with: wrapping the manifold and dp with heat wrap; low temp thermo; making the bumper opening larger. none of these have fixed it. I need some advise on what might fix this issue. maybe a cooling plate between the mani/rad or something? i can take pictures if anyone might think they have an idea... |
Re: b16T Ramhorn Overheating? (ef9civicgen4)
what kind of fan? mounted in front or behind the rad ?
Re: b16T Ramhorn Overheating? (dturbocivic)
its an oriellys 12 inch electric fan. the fan is a pull type so its on the back of the radiator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">what kind of fan? mounted in front or behind the rad ? </TD></TR></TABLE>
That was my Q also I have a ram horn and had the radiator very close to it with a slim fan mounted out front and car would overheat I pulled the top of the radiator a little towards the front of the car so I could put the fan back on the back side and overheating went away instantly |
Re: b16T Ramhorn Overheating? (adubaz7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adubaz7 »</TD></TR><TR><TD CLASS="quote">
That was my Q also I have a ram horn and had the radiator very close to it with a slim fan mounted out front and car would overheat I pulled the top of the radiator a little towards the front of the car so I could put the fan back on the back side and overheating went away instantly </TD></TR></TABLE> so, the verdict is...buy a 10" fan for the front? also, something my uncle mentioned is. that when a radiator is left sitting for a period of time, it can start to corrode fairly quick, and hurt its cooling efficiency. can this also contribute to my overheating problem? |
those relacement fans at autoparts stores do not pull enough cfm to "efficiently" cool the engine, trust me i know i used to have one.
Re: b16T Ramhorn Overheating? (slowsol95)
Is your fan just hooked up to the factory wiring, if so cut the wires, and run it to an in-cab switch. Leave your fan runn all the time, and if it gets to cold then just shut it off!!
Re: b16T Ramhorn Overheating? (grand champ)
bad idea grand champ..... what if the OP forgets to turn it on !
less things for the driver to worry about the better off. IMO |
make sure the fan is wired properly. i mounted my car quest 12" fan as a puller but wired it as a pusher, that caused me to overheat while sitting at a red light. and im still n/a at the moment, but will be boosted soon. once i re-wired the fan to pull air, overheating issues went away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsol95 »</TD></TR><TR><TD CLASS="quote">those relacement fans at autoparts stores do not pull enough cfm to "efficiently" cool the engine, trust me i know i used to have one.</TD></TR></TABLE> this could also be true, ive had friends who have had this problem. buy a good slim fan from one of the h-t sponsors. i think most of the slim fans sold on this forum are about 1600cfm, whether it be 10 or 12". |
Re: b16T Ramhorn Overheating? (MeanGreenMachine)
i already have the fan wired on all the time. so thats not the problem, and it is pulling air, not pushing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9civicgen4 »</TD></TR><TR><TD CLASS="quote">i already have the fan wired on all the time. so thats not the problem, and it is pulling air, not pushing.</TD></TR></TABLE>
Do not put another fan on the front. See my post here. https://honda-tech.com/zerothread/2066224 |
Re: b16T Ramhorn Overheating? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">
See my post here. https://honda-tech.com/zerothread/2066224</TD></TR></TABLE> did your autozone fan not cool at all, or it cooled the motor but just not enough? i got me a carquest 12" slim fan for FREE from a buddy, and was wondernig how it would hold up on a boosted motor, as im not boosted right now, and i believe my fan is rated @ about 800cfm as well.. so far its doing good for now considering the triple digit weather that has been going on in my area... |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">
did your autozone fan not cool at all, or it cooled the motor but just not enough? i got me a carquest 12" slim fan for FREE from a buddy, and was wondernig how it would hold up on a boosted motor, as im not boosted right now, and i believe my fan is rated @ about 800cfm as well.. so far its doing good for now considering the triple digit weather that has been going on in my area...</TD></TR></TABLE> It wasn't enough without having the heat on all the time. Summers with heat on blow big donkey nutz. https://honda-tech.com/forums/images...s/emsmilep.gif Save yourself the headache and ditch that fan. |
is it a stock radiator?
Save yourself the headache and ditch that fan.</TD></TR></TABLE> i have my carquest 12" slim fan mounted on a fluidyne rad, but i doubt that would make a difference, or does it? i may ditch the fan later, and then purchase me a 1600cfm rad... |
I had the same problem with my ramhorn. Everytime i hit boost i would overheat until i started moving again without being in boost. IT was all on a stock radiator. once i changed to a fluidyne and pusher fan never had a problem since. Hope that helps. https://honda-tech.com/forums/images/smilies/emthup.gif
