B16a Turbo Possibilities?
Old Oct 21, 2003 | 03:22 PM
bbadillo's Avatar
Default B16a Turbo Possibilities?
im trying to find out what isa a good turbo set up for a b16a in a 93' Honda Civic.... Im looking to spend no more than 3,000 dollars in the process along w/ knowing what turbo i need to know the mods that need to be preformed w/ the turbo. As i said im looking to spend no more than 3,000 dollars for the whole deal... Oh yea the b16 is stock
Old Oct 21, 2003 | 03:29 PM
redline201's Avatar
Default Re: B16a Turbo Possibilities? (bbadillo)
search is your freind
i researched this stuff for about a year before i bought my setup
use the search function and look in the forced induction archives
tons of info in there
Old Oct 21, 2003 | 03:40 PM
bbadillo's Avatar
Default Re: B16a Turbo Possibilities? (redline201)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline201 &raquo;</TD></TR><TR><TD CLASS="quote">search is your freind
thats why im asking! i dont have a year i have until december 12th
Old Oct 21, 2003 | 04:27 PM
NOSED_CRX_VTEC's Avatar
Rush the setup=Dead motor
Spend time=High power/long living motor
In other words when you rush you cut corners that you shouldn't cut.
I learned that the hard way!!! Now now need to rebuild the motor after bang bang..
Old Oct 21, 2003 | 04:32 PM
bbadillo's Avatar
Default Re: B16a Turbo Possibilities? (NOSED_CRX_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOSED_CRX_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Rush the setup=Dead motor
I learned that the hard way!!! Now now need to rebuild the motor after bang bang..</TD></TR></TABLE>
well thats why i am asking what is safe because i dont want to blow my car up
Old Oct 21, 2003 | 04:36 PM
Don't use the v-afc hack (they say its good but it aint) and go with Hondata,
Thats a start but it all comes down to how much power you want???
Old Oct 21, 2003 | 04:46 PM
TurboJesse
Guest
Posts: n/a
Ive spent right around 3k, maybe alittle more, including tuning, etc...
Old Oct 21, 2003 | 04:52 PM
Default Re: B16a Turbo Possibilities? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">Ive spent right around 3k, maybe alittle more, including tuning, etc...</TD></TR></TABLE>
It's going to cost me about that to rebuild the motor but it should be pushing some big numbers after.
It's going to take months but i cant wait.
Old Oct 21, 2003 | 04:55 PM
bbadillo's Avatar
what kind of setup are you running... and on what engine?
Old Oct 21, 2003 | 04:59 PM
TurboJesse
Guest
Posts: n/a
b16a
inline pro headgasket
arp studs
t3/t4
equal length mani
hondata s100
hp #'s in sig.
Old Oct 21, 2003 | 05:45 PM
bbadillo's Avatar
do you have any fuel or compression mods or adjusments done?
Old Oct 21, 2003 | 05:46 PM
TurboJesse
Guest
Posts: n/a
hondata s100, DSM 450's, walbro fuel pump, ....The headgasket lowers compression from 10:4:1-9:4:1
Old Oct 21, 2003 | 05:57 PM
redline201's Avatar
nice numbers man
Old Oct 21, 2003 | 06:16 PM
ReVtecSi's Avatar
where did you get the headgasket from? I talked to Stan at Inline about 1 month ago and he said that for my b16 the headgasket will lower it to like 9:1
Old Oct 21, 2003 | 06:39 PM
TurboJesse
Guest
Posts: n/a
Default Re: B16a Turbo Possibilities? (ReVtecSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReVtecSi &raquo;</TD></TR><TR><TD CLASS="quote">where did you get the headgasket from? I talked to Stan at Inline about 1 month ago and he said that for my b16 the headgasket will lower it to like 9:1</TD></TR></TABLE>
i was under the assumption that the 3mm headgasket lowers comp. 1pt It will prolly be right around 9:1 on a 10:2:1 b16a, but mine is 10:4:1 stock..
Old Oct 21, 2003 | 06:52 PM
ITRswapandslow's Avatar
max rev BOV'S SUCK ******* AND LEAK
and chipped ecu's can do anything hondata can. there are MANY 500whp cars running them. remember...there is a world out there beyond honda-tech
Modified by eh2nboost at 7:20 AM 10/22/2003
Old Oct 21, 2003 | 07:03 PM
TurboJesse
Guest
Posts: n/a
Default Re: (eh2nboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh2nboost &raquo;</TD></TR><TR><TD CLASS="quote">dude
max rev kit with different BOV
and then get a CHIPPED ecu, since it is JUST AS GOOD AS HONDATA</TD></TR></TABLE>
I don't think maxrev makes kits anymore, I have a friend running their kit and the bov is fine. Also chipped ecu's aren't for everyone, im not dissing them at all but how many 500+whp cars are there on hondata compared to chipped ecu's?
Old Oct 22, 2003 | 03:43 PM
bbadillo's Avatar
Default Re: (Mpir3)
^^^^ i agree on this one
Old Oct 22, 2003 | 03:53 PM
qsilver074's Avatar
Can you be more specific?
I assume you have the del Sol VTEC with the stock B16?
You have an Inline Pro 3mm Headgasket
ARP Head Studs
Which t3/t4 turbo are you running?
What piping?
Which equal length manifold?
Did you make the map you are using in Hondata or is it a baseline?
Do you have an intercooler? If so, which intercooler?
Which wastegate?
Which BOV?
Details are key here.
Old Oct 22, 2003 | 03:59 PM
TurboJesse
Guest
Posts: n/a
Default Re: B16a Turbo Possibilities? (qsilver074)
I'll try my best to remember what i have..lol
JDM SIR II b16a
Inline pro 3mm Headgasket
ARP headstuds
SS Autochrome Manifold (obx/Meng)
Tial 35mm Wastegate
3" open downpipe
2.5" IC piping
Max rev intercooler
Sheepdog BOV (Real reason i made power )
DSM 450's
hondata s100
Walbro 255hp fuel pump
Tuning was done by Boosted Hybrid
Old Oct 22, 2003 | 04:04 PM
qsilver074's Avatar
Can I have your Hondata map?
By the way, what are the specs on the turbo?
Old Oct 22, 2003 | 04:38 PM
TurboJesse
Guest
Posts: n/a
Default Re: (qsilver074)
ahh i knew i forgot something...garrett t3/to4e 60 trim .63ar...lol
CTGrey06RSX-S
Nov 15, 2012 04:11 AM
SIguy626
Aug 23, 2005 09:42 PM
Driving_A_Crx
37
Mar 18, 2005 02:26 PM
ilovemycrx
12
Oct 6, 2004 10:32 AM
thinknology
Jul 10, 2004 03:44 PM
