b16 turbo
Old Apr 15, 2008 | 12:32 PM
imsebtactular's Avatar
Default b16 turbo
hey guess so im building a setup for my b16,
planning on running 6psi.
i got what i think is everything.
-chiped ecu with a basemap on turbo edit.
-intercooler
-turbo
-oil feed and return lines.
-manifold
-wastegate.
-boost controller
-internal wastegate,
-bundged oil pan,
-downpipe
-bov
-boost air fuel auto meter gauges.
Am i missing anything and any recomendations?
Old Apr 15, 2008 | 02:03 PM
94GSRCivic's Avatar
Default Re: b16 turbo (imsebtactular)
lets not forget about your fuel setup
Old Apr 15, 2008 | 02:54 PM
Depeche's Avatar
Do you have all of your intercooler piping? Flanges? Are you planning on having someone tune the car? How many miles on the engine? Good start it seems
Old Apr 15, 2008 | 03:17 PM
92civicx's Avatar
Default Re: b16 turbo (94GSRCivic)
injectors
fuel pump - optional
Old Apr 16, 2008 | 01:48 PM
Kelb's Avatar
i plan to boost my b16 as well. its stock at the moment. going with peakboost kit. 540cc injectors, walboro 255lph fuel pump..
You excited for boost? i should have mine set up in a few months.
the peakboost kit is 2895 right now, then buy your own injectors/fuel pump.
tune is goin to be spendy. live in idaho.
Old Apr 16, 2008 | 02:11 PM
Schister66's Avatar
Man U FTW
Default Re: (Kelb)
Just because i feel like typing right now, i'll give a complete list of parts you'll need.
-turbo
-manifold
-downpipe/dumptube
-full exhust
-wastegate (external preferred)
-bov
-charge piping
-injectors
-walbro 255lph
-clutch
-chipped ECU
-oil lines
-gauges (i run just a boost, but you can add more as you wish)
-vac manifold
-a good tune
Old Apr 18, 2008 | 05:37 AM
neoc03's Avatar
Default Re: (Schister66)
Make sure you find a good tuner. The most important part of your build is going to be your tune. What size turbo are you planning on running? What are your hp goals?
Old Apr 18, 2008 | 09:11 AM
Schister66's Avatar
Man U FTW
Also, dont plan your goals in terms of PSI...its not a good indicator of anything really. I'd get into why, but its a long description. Basically, set a power goal and run whatever PSI required to get there. The safe range for your B16 is around 300whp
93da9kid
Jan 30, 2011 07:08 AM
ryanangelo212
Nov 28, 2009 02:58 PM
Silkk Tha Shocker!
Jun 3, 2006 10:05 PM
sidan
Jan 7, 2004 07:24 PM
89b16hf
Dec 16, 2003 07:58 PM
