b16 tranny good for boost?
Old Nov 10, 2005 | 05:48 AM
JDM00SI's Avatar
Default b16 tranny good for boost?
Sup,
I'm going to be boosting 20psi+, making over 500whp. The thing is i will be running a b16 tranny, which as we know have the shortest gear ratios. this is probably the 38323th thread about tranny vs. tranny. I read a thread in which we had the same debate, they said something about the b16 being even better.
Should i change trannys or keep my b16?
Thanks
Old Nov 10, 2005 | 05:49 AM
JDM00SI's Avatar
quick tranny bump
Old Nov 10, 2005 | 07:36 AM
KeyserSoze's Avatar
Default Re: (JDM00SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote"> Gear ratios are merely a way to trade torque for rpm. With a higher numerical gear ratio, you are putting more rpm at the wheel. With closer gear ratios, you are able to stay at a higher rpm in between shift points. Something like the LS transmissions are suited more towards the broad torque curve/low reving LS engine. It keeps you in the peak torque area in between shifts. The ITR/SI/GSR transmissions keep the rpm's built up in between shifts, to stay in the more peaky powerband.
Having said that, for the track the itr/si tranny is the best hands down. Most high whp turbo engines are operating between 5.5-9k, and having their shift points in between. In combination with a tall slick size (24.5"+), and the high shift point (8.5-9k), you are able to keep the engine operating within the optimum torque curve.
With the LS transmission, between shifts it would possibly drop you out of the optimal powerband and therefore make you slower. Gearing simply put allows you to stay in the powerband of your engine in between shifts.
The myth that you stay in gear longer with the LS transmission makes you faster is purely false. Think about that statement for a second. Acceleration is the measure of velocity over a unit time. Watching the rpms climb on the tach during a 3rd/4th gear pull, they would be climbing slower than with the si/itr tranny. Looking at the definition of acceleration as a measure of velocity over a unit time, the engine would be getting to the same velocity over a slower time lapse. This would yield slower acceleration, and simply put make you slower.
Having said that, the gsr transmission is probably the best balance of a street/strip transmission. The gearing is a little less aggressive as the itr/si transmissions, which will yield a little more traction. For all out acceleration si/itr tranny wins hands down. For a slower car, go with the LS transmission.
Old Nov 10, 2005 | 08:05 AM
boostfeen's Avatar
Default Re: (KeyserSoze)
..that explains it, in a nut shell
Old Nov 10, 2005 | 09:07 AM
JDM00SI's Avatar
Default Re: (boostfeen)
Thanks i will be purchasing a b16 tranny w/ a quaife today.
Old Nov 10, 2005 | 09:50 AM
KeyserSoze's Avatar
Old Nov 10, 2005 | 11:57 AM
beerbongskickass's Avatar
All the fast guys use b16 tranny's or gearing. They also rev really high and have huge slicks.
madcrx69
Mar 23, 2009 12:32 PM
hspoon
Dec 8, 2006 12:45 PM
GTEC913
Jan 9, 2006 09:10 PM
YwanaV8
Dec 12, 2004 03:05 PM
bboylito
Jun 10, 2004 08:40 AM
