B&M fpr with an fitting braided lines??? question
ok, i have a b16a (1st gen) and im using the b&m fpr with an fitting fuel lines. im having some trouble trying to work these lines in with the b&m fpr and also the gauge. im sort of confused on how im going to get this setup to work. im running 6-an. any help or pictures of your setup would help me out.
Modified by japrex at 6:11 PM 7/30/2004
Not sure if it's possible, because the B&M unit uses the lower OEM portion of the regulator...you may have to get a better regulator. I am using the Fast-Turbo fuel line kit [I think it's -6AN] and an Aeromotive FPR. If you want I can post pictures.
