ARP head Stud Question: b18a block, b16 head.. HELP
Ive searched this, and it seems like there are different answers every time
b16 head, b18a block, LS/Vtec setup...
do i go with GSR Studs part number: 208 4303
or the b20 vtec w/b16 head... part number 208 4306
thanks in advance
thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">thanks, this is what im talkin about... everytime I read I get a different responce..
so why is the b20 with a b16 head a different part number then the GSR studs?</TD></TR></TABLE>
Same studs, different part number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">if your using a b16 head then use b16 studs</TD></TR></TABLE>
WRONG, it depends on the BLOCK you are using. different deck hight = different studs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buttsneeze »</TD></TR><TR><TD CLASS="quote">what about LS headstuds?</TD></TR></TABLE>
ls headstuds wont work, because the 2 center studs are longer than the others.
the correct headstud to use on an LS/vtec or b20 vtec is a GSR headstud. the b16 ones are too short, and you will pull the threads out of your block with them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">
too bad, since i have arp's for the LS already (in my current b18b setup) Guess i'll have to buy different ones b4 starting my ls/vtec setup........
CHRIST! Do NOT spread wrong information like this!
Use GSR headstuds.
Use GSR headstuds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">thanks man, I Ordered those ^^^^</TD></TR></TABLE>
Thanks!
Thanks!
ONLY reason why ls studs don't work is because the center two are too long, so if you can find two gsr headstuds or two "short" ls studs to replace the longer ones, it works perfect.
I found someone selling individual gsr headstuds for $10, so I bought two, and used them in my ls/vtec setup.
</TD></TR></TABLE>ONLY reason why ls studs don't work is because the center two are too long, so if you can find two gsr headstuds or two "short" ls studs to replace the longer ones, it works perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 »</TD></TR><TR><TD CLASS="quote">
know where i can find two for myself?
</TD></TR></TABLE>know where i can find two for myself?
Try searching around H-T, I don't know of anyone off hand, the guy I bought mine from probably sold all of his.
HamiltonRex
Jun 19, 2009 01:41 PM
Topdawgg
Mar 6, 2006 07:20 PM
