Apex'i Turbo Timer (H22a4)
Old Oct 1, 2002 | 12:22 PM
LordVtec's Avatar
Default Apex'i Turbo Timer (H22a4)
Anyone using an Apex'i Turbo timer on their lude? i need help figuring out how to install this thing... it says that you need a manufacturer's wire harness but of course there isnt one available.. I need help figuring out this install.. Any info you guys can offer would be grealy appreciated. Thanks !!
Old Oct 1, 2002 | 04:45 PM
B6teen's Avatar
Default Re: Apex'i Turbo Timer (LordVtec)
read the instructions duh just playing sup rob
Old Oct 1, 2002 | 04:58 PM
glagola1's Avatar
I'm running one on my 94 civic but I would imagine that honda didn't change much on their ignition switch wiring.
You'll need a volt meter to find the three wires the timer wants to tap into. Just gain access to the ignition wires coming out of the switch and start testing them with the key in the different positions.
It's pretty easy really. Also, if you are using the A/F meter which actually works pretty well you'll need to tap into the ecu's ground and O2 wire. It's best to use a manual of some sort to find those wires.
Do you already have the timer? The instructions point the way pretty well. If you don't have the instructions you can down load them from apex's web site.
Old Oct 1, 2002 | 07:36 PM
LordVtec's Avatar
Default Re: Apex'i Turbo Timer (turborex)
Hey mini me.. dont make me open up a can!! just kidding.. i found a diagram from apex on how to "hard wire" the turbo timer so i think i got it figured out.. all i need to do is open up my ignition and figure out what color wire is what.. should be lots of fun.. wanna come over and help me screw up my car?? i got a case of beer should you be interested.. lol...
Old Oct 1, 2002 | 07:38 PM
LordVtec's Avatar
Default Re: Apex'i Turbo Timer (glagola1)
thanks.. i have the instructions, just wasnt sure what wires in the ignition i should tap... i guess i was hoping someone could help me find the easy way out and avoid having to test the different wires.. no biggie.. will just have to sit there this weekend with the light tester..
Old Oct 1, 2002 | 07:57 PM
Quaalude's Avatar
red=white (+12V constant)
green=black/yellow (IGN 1)
blue=yellow (IGN 2)
[Modified by Quaalude, 11:58 PM 10/1/2002]
Old Oct 1, 2002 | 08:31 PM
LordVtec's Avatar
Default Re: Apex'i Turbo Timer (Quaalude)
you are a life saver.. thanks Quaalude..
Old Oct 2, 2002 | 07:13 PM
LordVtec's Avatar
blue=yellow (IGN 2)
Ok, so here is an update... I installed the timer, looks great and its working well.. accept for the fact that it really isnt giving me much of an A/F reading... when i set the timer to the O2 voltage reading it flashes between 960 and 10.0... and if i set it to A/F it sits at 20.0 (flashing)... Am I missing something? does all this have to be set, or should i check the connection to the O2 sensor? I remember hearing something about it having to be set up once its installed.. any info you guys can offer would be greatly appreciated...
Update: Problem solved.. i had a faulty connection on the o2 sensor wire... its working great now...
[Modified by LordVtec, 11:51 PM 10/3/2002]
Old Oct 27, 2002 | 01:54 PM
LODOSS's Avatar
i don't think u set up the timer correctly
or it is possible that your a/f ratio is out of ranged cause eithe ryour o2 sensor is malfunctioning or it is detecing a very very lean condition
TEG777
Jul 21, 2005 08:42 AM
fourv2
Jun 24, 2005 04:03 PM
shauminside
Honda S2000
Jul 19, 2004 10:22 AM
sinfulDB1
Oct 30, 2003 10:53 PM
glagola1
Oct 24, 2003 12:40 PM
