apexi afc computer info?????
i have a 91 honda civic si 1.6 with the pm6 computer non v-tech and was wondering if anyone had done a hook up like this and if so how to hook witch wires to what i called apex and they said they have never done a setup like that so they dont know so if u have any information please share the wealth!
Gord 192whp sohc d16a6
you need a ecu pinout diagram.
if you know what the afc wiring is (which wiring is power, ground, tps, etc...) then just match and tap them into the corresponding ecu wiring per the pinout.
I used the wiring diagram for the B16A CRX (SiR, DOHC VTEC) that came with it. I can't remember if all the colors were correct, but the locations were for sure.
-Dustin
-Dustin
This is the wiring diagram i followed to hook mine up....
http://www.geocities.com/motor....html
This is another site to use to help get you started with setting up for afc hack if your unsure of what to do...
http://www.thedropshop.tv/vafc.htm
insulting my mom, real mature, **** you man, you have been GIVEN all the info you need, so do it or STFU. if you want someone to do it for you than go to a ******* shop.
-Dustin
-Dustin
Monster R
Honda Civic (2006 - 2015)
Oct 4, 2009 06:56 PM
95turbodteg
Feb 27, 2007 05:59 PM
