Apex VS Greddy?
Hi, I have a 94 Civic EX Coupe(d16z6), and I´m thinking to upgrade it with a Turbo kit.
I´m looking for the Greddy TD40H-15G or the Apex 705-H001 Turbo Kit.
Performance on both seems to be good, but im not sure which one is best.
help please?
thanks
help please?
thanks
although I have no direct experience with it, the Apex looks really really well put together.
But, you cant go wrong with the GReddy system either.
Good luck
Good luck
apex gives your a ball bearing turbo, greddy doesn't
thats what i know
not much on either one
all i know is you'll run 15's with it or faster
also, i smoked a sohc hatch with greddy turbo and intercooler
with my stock gsr, cold winter nite too i ran 15.0 with it.
thats what i know
apex also cost a lot more compare to greddy.. if you are plannin on rebuilding the engine then i guess go for the apex and boost high and have fun... but if not, i would rather go with a smaller turbo that spools really fast.
Ball bearing i$ better until the turbo need$ a rebuild. Yeah, it'll $pool a little fa$ter, it will co$t alot more when the turbo ha$ to be taken apart. How much are the two kit$ in compari$on?
Smarter than you
For the money on your car i would tell you just to swap in a B18C motor.. you will be faster with that motor stock then turboing your motor on moderate boost. Plus its much less of a hassle and is alot more reliable.. And if u want to go faster after that and go turbo the possiblilties are endless..
The greedy cost $1600 aprox and the apex $1800..
i second an engine swap.
like i said before, i burnt a turbo sohc with my stock gsr.
streets and track.
even with a b16 u'll be just as fast those are only 2k
b18c1 are around 2.5k
streets and track
streets and track
And I've "burnt" an assload of modded GS-R's, Si's and a yes, couple hybrids in my SOHC Turbo on mild boost... it's all about the driver
Nicks95GSR
Apr 4, 2012 12:23 PM
