apex map sensor
Old Sep 7, 2006 | 11:07 PM
nz_turbo_type_r's Avatar
Default part number for apex map sensor
hey there, i put a post up on here a while back about my jdm 97 itr i have just finished turbo charging, well almost finished.. my problem is that no one in new zealand has any idea about the map sensor im trying to find from apex to run on my itr (car runs power fc). someone on here posted picks up of the map sensor and wiring loom which i passed onto the apexi supplier here in new zealand and he still had no idea, if someone could help me out a little more with the part numbers you would be saving me alot of headaches. thanks in advance
Modified by nz_turbo_type_r at 2:31 PM 9/8/2006
Old Sep 8, 2006 | 01:30 PM
Default Re: apex map sensor (nz_turbo_type_r)
please hook me up someone, i know someone on here knows cause there were pictures posted of the parts, but i neeeeeed part numbers please
Old Sep 9, 2006 | 09:52 AM
TheShodan's Avatar
Moderator
Give these guys a shout. I'll have to find the part numbers for you later.
http://www.modyourcar.com.au/p...d=450
Old Sep 9, 2006 | 10:52 AM
jDMJeRk's Avatar
You can always run a GM 3 Bar if you cant find it. Its probably cheaper that way too. Just food for thought
Old Sep 9, 2006 | 01:55 PM
Default Re: (jDMJeRk)
sweet ill check them out, yeah i have been told gm 3bar will work no worries, but then ive also heard from the top tuner of power fc's in new zealand that i need apex map sensor, i just want to do it once and do it right
Old Sep 12, 2006 | 09:55 PM
jDMJeRk's Avatar
using a 3 bar is still the right way.... all you need is to change the map in the PIM vol tab
lostinmiself
Apr 19, 2012 06:17 PM
K7-1Ktrevor
Dec 25, 2009 06:18 AM
spockeg
Engine Management and Tuning
22
Oct 19, 2009 07:54 PM
Nichelson_Performance
Jun 18, 2008 08:00 PM
