anyone here use supertech pistons for turbo application?
Old Nov 2, 2011 | 05:06 PM
jdmcivic2fast's Avatar
Default anyone here use supertech pistons for turbo application?
have always use wiseco,je and cp, just wanted to try sumthing different, the price on the supertech pistons are good so its kinda what got me looking at them but want to know about these pistons before i buy em....
are they as durable as the wiseco's or je's?
what kind of material are they?
how much do these pistons expand when operating in extreme conditions?
are thier piston rings durable?
do they carry something under 10:1cr for the 81mm size? wanted 9:1cr unless 10:1cr is good too.
anything i should know plese fill me in.
it's not going to be a big power motor trying to keep it around 400-450ish
set-up will be
GSR head
ITR cam
gt3076r turbo
LS block stock sleeves
81mm bore
LS crank
eagle rods.
Old Nov 2, 2011 | 06:09 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: anyone here use supertech pistons for turbo application?
I just spent a few minutes on google and I found answers to most of your questions. Were you looking more for opinions?
Old Nov 2, 2011 | 07:12 PM
ryguy2588's Avatar
I used Supertech pistons in mine until I cracked a sleeve and got a sleeved block with a different bore. They're the cheapest forged pistons I could find, and I love all Supertech stuff so I figured I'd try em. They were great pistons when I had them. They make compression under 10:1. Go to this link. This is where I ordered mine from.
http://www.jhpusa.com/store/pc/viewP...0&idcategory=0
Old Nov 2, 2011 | 11:50 PM
v.i.gsr's Avatar
I run supertech pistons in my 84mm gsr setup.. 9:5.1 compression, 15psi daily and 32psi @ the track..
No complaints as yet.. For the price you cant beat them.
A few years back miller tune a setup with some supertech to 850hp I think it was...
Old Nov 3, 2011 | 03:07 AM
MR.johnson's Avatar
i made 650 all last year on them.
we talked to them at the PRI show, they said around 700 is the most they would go.
Old Nov 3, 2011 | 08:03 AM
d16z6Tcrx's Avatar
supertech here. love them. very quiet. 600+ at the track.
Old Nov 3, 2011 | 06:46 PM
was there any modifications you guys had to do to the superech pistons, or just dropped in and go?
Old Nov 3, 2011 | 06:49 PM
00Red_SiR's Avatar
All Motor Mentor
You have to have the block bored to mach each piston in it's respective cylinder, with the correct amount of PTW (piston to wall) clearance.
Old Nov 3, 2011 | 07:06 PM
lol thanks I know that part, i was more concern about maybe if the weight of each pistons are not identicle or close enough to eachother and needs balancing
Old Nov 3, 2011 | 07:14 PM
ryguy2588's Avatar
As long as the cylinders are machined for the ptw clearances, they just drop right in.
Old Nov 4, 2011 | 09:53 AM
d16z6Tcrx's Avatar
i didnt use the recommended specs. i went with .0045. still no slap when cold.
Old Nov 7, 2011 | 04:44 PM
Is 10:1cr good for daily driven boost applications? wanted 9:1-9.5:1cr but supertch dont carry them in 81.5mm bore. whats the pros and cons running 10:1cr vs 9:1-9.5:1cr?
Old Nov 7, 2011 | 05:44 PM
TheShodan's Avatar
Moderator
No cons, just pros when tuning with 92+ octane fuel so they can resist knock.
Old Nov 7, 2011 | 06:46 PM
so that means im limited on compression because i only have 91oct here??
Old Nov 13, 2011 | 09:06 PM
m3tech95's Avatar
Im looking to get these pistons for my b16a 84mm shooting for 600whp...my only concern is, are the rings that supertech provides with it good? likely to go with Eagle H beams since im only going for 600....trying to keep things simple as possible....cr. 10:1 stock R/s have a great tuner who will be handling the setup for the powerband...
Old Nov 13, 2011 | 09:40 PM
racebum's Avatar
if i remember right supertech has their pistons made by someone..wanting to say it's either wiseco or mahle, can not remember which
edit: i knew it, mahle
https://honda-tech.com/forums/drag-racing-36/supertech-pistons-anyone-2681826/
which brings up another good point. real mahle 4032 pistons are $450/set
could be the exact same piston? if it is the rings are good and high quality steel
mahle is the world's largest piston manf. and oddly not a name we see on honda tech all that much.
Old Nov 13, 2011 | 11:06 PM
Redline130's Avatar
I'm currently using Supertech pistons with 660+ whp. Been using them for over 3 years with no issues with the pistons or rings.
Old Nov 14, 2011 | 06:34 AM
m3tech95's Avatar
what rods were you guys running over 600hp with the Supertechs? Im at the stage where I will buying a piston/rod combo very soon:
84mm B16A GE sleeved
T3 Topmount
Precision 6262 83ar JB
RC1000 injectors
Walbro 340lph
Looking to make 600 or more
Old Nov 14, 2011 | 08:52 AM
v.i.gsr's Avatar
Mahle makes them..
Old Nov 14, 2011 | 09:32 AM
ugly88si's Avatar
i heard they bought one of mahles factories .i called supertech one day and they said they make all their stuff. ive used mahle and supertech and there are a few differences between the two . i think supertech ships their pistons with nippon gas nitrided rings in the white boxes . i think nippon also makes rings for arias . either way they are the best bang for your buck ive used them n/a with nitrous and on boosted apps and have zero complaints. b from dfr uses them on his race car
Old Nov 14, 2011 | 09:35 AM
BigMike0147's Avatar
Have some in my LS motor right now. No complaints as of yet and their customer service is awesome!
Old Nov 14, 2011 | 09:52 AM
rich7777's Avatar
^^^^ The proof is in the pudding
Old Nov 14, 2011 | 11:59 AM
b18c1Monster's Avatar
yea that was my car. still using the same pistons to this day. its been 4 years with countless passes at the track and on street. no complaints
Old Nov 14, 2011 | 08:48 PM
m3tech95's Avatar
Icon3 Re: anyone here use supertech pistons for turbo application?
Old Nov 14, 2011 | 09:41 PM
went with the supertech 9:1cr in 81.5mm bore, order it a few days ago and shoud be here by tommorrow or wensday yay!!!!
