Anyone ever seen this happen?
Old Nov 25, 2006 | 05:56 PM
M.A.R.C.'s Avatar
Default Anyone ever seen this happen?
This happened after my last pass down the track
at first it looks like just a blown hg
Notice the inner sleeve is still in one piece. i'm thinkin the gasket blew so hard it separated the outter lining from the sleeve
btw this was a 81.5mm darton sleeved block
9:1 pistons
sc61 @ 26psi
~550whp or so (i dynoed 511whp @ 23psi)
I rode the limiter in 3rd too long (didn't realize i was on it... newbie mistake)
Old Nov 25, 2006 | 06:35 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Anyone ever seen this happen? (M.A.R.C.)
i've never seen a gasket do that.... damn
and you just seem to have bad luck with motors... is the inner sleeve ok from what you can tell?
Old Nov 25, 2006 | 06:40 PM
yugadnoh's Avatar
fucked up sleeve job, who did it?
Old Nov 25, 2006 | 06:46 PM
crx2fast's Avatar
Default Re: Anyone ever seen this happen? (yugadnoh)
dosent even looked sleeved to me
Old Nov 25, 2006 | 06:47 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Anyone ever seen this happen? (crx2fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2fast &raquo;</TD></TR><TR><TD CLASS="quote">dosent even looked sleeved to me </TD></TR></TABLE>
dartons are nothing but ductile iron.... no aluminum outer
Old Nov 25, 2006 | 06:52 PM
EFsSuck's Avatar
Default Re: Anyone ever seen this happen? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
dartons are nothing but ductile iron.... no aluminum outer</TD></TR></TABLE>
Darton makes many different kinds of sleeves, infact they make lots of the sleeves for many places that sleeve them... they make those T braced ones and 'replacement' sleeves that would look just like the stock Honda ones...
Old Nov 25, 2006 | 06:58 PM
yugadnoh's Avatar
the block is sleeved.it looks like they cracked the aluminum when they put the sleeve in.
Old Nov 25, 2006 | 07:16 PM
seen4ever's Avatar
i've never heard of a 'sleeved' block using the stock aluminum up that far, ****** is definatley not sleeved correctly with a full sleeve. Who sleeved the block?
Old Nov 25, 2006 | 07:43 PM
EFsSuck's Avatar
Default Re: Anyone ever seen this happen? (seen4ever)
http://www.importbuilders.com/pictures/b16at3.jpg
"Dry sleeve" motor by ImportBuilders
"This is the sleeving style to choose for all motor applications, and for street cars with mild to moderate levels of boost. This sleeve is not as resistant to detonation and tuning problems as the flanged or the Darton, but has a thicker OD overall than both other styles. For example, if your going to boost 15-20 PSI and you are using pump gas and there is a chance you could detonate the motor, you want to step up to the flanged or the Darton mid. This style of sleeve has run 9's all motor, and has run 8's under boost. I have been on the dyno personally doing 40 PSI on these, its very strong.
OD THICKNESS:
B series: 89.5 MM"
Old Nov 25, 2006 | 08:27 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote"> i've never seen a gasket do that.... damn
and you just seem to have bad luck with motors... is the inner sleeve ok from what you can tell?</TD></TR></TABLE>
the inner sleeve looks totally fine to me. the sleeve job was done by race engineering from what my friend told me (block came in the car i bought from him)
Old Nov 25, 2006 | 08:38 PM
yugadnoh's Avatar
it looks like they made it press fit and cracked the aluminum when they installed the sleeve.
Old Nov 25, 2006 | 08:39 PM
M.A.R.C.'s Avatar
i've cracked a sleeve on my LS-T and it was A LOT nastier... there wasn't any inner sleeve that held up. it just blew straight through.
Old Nov 25, 2006 | 08:42 PM
JDMCRX's Avatar
expletive marc thats blows
Old Nov 25, 2006 | 08:44 PM
M.A.R.C.'s Avatar
Default Re: Anyone ever seen this happen? (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">expletive marc thats blows</TD></TR></TABLE>
meh not really. i sold the shell a week or two ago and i've parted out most of the setup. the block/head/tranny and a few other accessories are the only thing left
Old Nov 25, 2006 | 08:47 PM
G
sh!t happens.
Damn that is crazy...
Old Nov 25, 2006 | 08:49 PM
M.A.R.C.'s Avatar
Default Re: Anyone ever seen this happen? (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT &raquo;</TD></TR><TR><TD CLASS="quote">Damn that is crazy...</TD></TR></TABLE>
lol i'm used to that. i swear my motors always break in the oddest of ways.
Old Nov 25, 2006 | 09:31 PM
user 98292739's Avatar
so can you still use this block since the inside sleeves looks ok?
Old Nov 25, 2006 | 09:32 PM
M.A.R.C.'s Avatar
Default Re: (The Lobster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">so can you still use this block since the inside sleeves looks ok?</TD></TR></TABLE>
dunno... anyone willing to chime in on that? if not this block is getting tossed.
Old Nov 25, 2006 | 09:38 PM
dunkd's Avatar
try contacting Darton. they were very useful in assessing problems I had with a darton sleeved block last year.
Old Nov 25, 2006 | 09:39 PM
M.A.R.C.'s Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">try contacting Darton. they were very useful in assessing problems I had with a darton sleeved block last year.</TD></TR></TABLE>
thanks for the heads up. i'll try to get some better pix of the sleeves before i contact them.
Old Nov 25, 2006 | 10:06 PM
EFsSuck's Avatar
Default Re: (M.A.R.C.)
if your gonna throw it away ill PM you my address... im willing to bet its runnable... but obviously you wont have the headgasket sealing surface as before...
Old Nov 25, 2006 | 10:09 PM
M.A.R.C.'s Avatar
Default Re: (EFsSuck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFsSuck &raquo;</TD></TR><TR><TD CLASS="quote">if your gonna throw it away ill PM you my address... im willing to bet its runnable... but obviously you wont have the headgasket sealing surface as before...</TD></TR></TABLE>
yeah but i'm also willing to be that piece hanging off may cause the gasket to blow again from once it sees any vibrations from the motor running, etc.
Old Nov 25, 2006 | 10:10 PM
qfast817's Avatar
well i guess you had to ride the rev limiter longer then 3 sec
Old Nov 27, 2006 | 12:33 PM
liam821's Avatar
25 Year Member
Default Re: (qfast817)
wow marc - you always blowup all your sh*t.
liam
Old Nov 27, 2006 | 12:36 PM
M.A.R.C.'s Avatar
Default Re: (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">wow marc - you always blowup all your sh*t.
liam</TD></TR></TABLE>
hell yeah niggra... i don't play lol. stock s2000 @ the autocross for me for a while!
