Any help would be appreciated!
Old Jun 20, 2016 | 11:37 AM
cwwj83's Avatar
Default Any help would be appreciated!
I have a 92 civic cx D16Z6 turbo. Ok my problem is it's wanting to cut off and smoke very bad, it just recently started happening. Never had a problem with it until recently i drive the car on the daily. Back to my question. Ok so i can be driving down the road and it will just cut off like its out of gas and just start pouring smoke out the tail pipe and if you try to give it gas it won't do anything like it ran out of gas. I'll pull over and have to pump the gas for a min while I'm trying to crank it and it will start and run fine. I'm thinking my fuel pump is going bad but it hasn't been long since i put a good one in it. But i don't see how that would explain the white smoke it pours out the tail pipe. I originally thought i blew a head gasket but its fine, so i was just curious as to what you guys thought. It's tuned on 12 pounds running RC 750 injectors. Any help would be appreciated. Thanks!!
jdmISmyGOD
10
Apr 16, 2013 08:15 PM
Thenderson2011
Sep 21, 2012 12:15 PM
Xxcivic99xX
Nov 11, 2008 09:56 AM
LsTegDriver
Aug 28, 2008 07:19 PM
pr0digy1
May 8, 2002 09:08 AM
