another hose and t-bolt clamp ?
Old Apr 29, 2004 | 06:50 AM
Prelude91siT's Avatar
Default another hose and t-bolt clamp ?
ok if i'm running 2.5" piping exactly what size do i need to get so it can fit around the silicone hose correctly also what size reducer and clamp do i need to go from t/b to 2.5" piping. thanks this is much appreciated.
Old Apr 29, 2004 | 06:59 AM
FOrSfEd's Avatar
Default Re: another hose and t-bolt clamp ? (Prelude91siT)
If you have 2.5 piping then you will need a coupling for 2.75 and a t bolt for the same 2.75 or a lil bigger
Old Apr 29, 2004 | 07:07 AM
ok thanks what about the t/b? if anybody has exactly what i need hit me up. if i had where going by exact size then i would need 6 2.5" 1 2" and what ever the t/b uses? can somebody interpert that into exactly what i need please. thanks
Old Apr 29, 2004 | 07:21 AM
FOrSfEd's Avatar
Default Re: (Prelude91siT)
I used a transition 3-2.75. What piping kit are you using.
Old Apr 29, 2004 | 07:22 AM
quikB18B's Avatar
Well seeing as how transition hoses are expensive as **** $$$ usually $17+ for one, I used a 2.5 coupler on my piping to throttle body, with a little effort the silicone will squueze nice and tight over the throttle body.
Im not sure about other T bolt clamp Websites but the one I ordered from I think has tables to tell you which size you need example. I think they are labeled T bolt clamps for X size piping.
http://www.vecco.net
Old Apr 29, 2004 | 07:28 AM
FOrSfEd's Avatar
Default Re: (quikB18B)
Yeah no joke about the transition hose's thanks for the input about that website.
Old Apr 29, 2004 | 09:05 AM
FwdCivicHatch's Avatar
Default Re: (FOrSfEd)
http://www.mcmaster.com also has a lot of **** like that to, also with charts.
Charlie Moua
Oct 23, 2010 06:05 AM
joshcivic00
Jun 16, 2005 12:02 PM
ExplicitSpeed
Apr 1, 2004 09:42 AM
TurboB18C1
Mar 27, 2004 10:55 AM
