aluminum ic piping
Old Oct 28, 2003 | 05:05 PM
redboost10's Avatar
Default aluminum ic piping
is aluminum the most recommended piping material or is aluminized steel a better choice? wast sure if aluminum can handle the heat that much or not.
Old Oct 28, 2003 | 05:13 PM
MachAF's Avatar
Default Re: aluminum ic piping (tgh99si)
your not sure if aluminum can handle heat? Your engine block is aluminum.
Plus what temperatures do you think IC pipes are going to be exposed to?
Old Oct 28, 2003 | 05:38 PM
boosted hybrid's Avatar
Aluminum is a better choice for material due to:
1. Higher thermal conducitivity, thus dissapating more heat under boost, ie lower intake air temps giving increased air density.
2. Aluminum has a natural luster, can polish very nicely and doesnt rust. Aluminized over time looks like crap unless you paint the surface. I did my IC piping out of aluminized since it was all I had laying around the shop this summer. I am redoing the piping in aluminum this winter.
Welding thin gauge aluminum piping is tricky, more so than steel. You'll have to find someone that is comfortable welding aluminum (assuming you cant weld yourself), which costs more than steel would.
Old Oct 28, 2003 | 05:40 PM
Mase's Avatar
Default Re: aluminum ic piping (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Aluminum is a better choice for material due to:
Welding thin gauge aluminum piping is tricky, more so than steel. You'll have to find someone that is comfortable welding aluminum (assuming you cant weld yourself), which costs more than steel would. </TD></TR></TABLE>
100 % agree
Old Oct 28, 2003 | 05:43 PM
Ricey McRicerton's Avatar
Default Re: aluminum ic piping (Mase)
Agreed. Aluminum in the way to go. Greddy puts aluminum piping in all of their kits...so it must be good.
Old Oct 28, 2003 | 05:51 PM
xenocron's Avatar
Default Re: aluminum ic piping (Ricey McRicerton)
Besides Kteller's site...anyone know where to get aluminum bends and straight pipes?
Old Oct 28, 2003 | 05:53 PM
Default Re: aluminum ic piping (xenocron)
I think JC Whitney or Summit sells them. Let us know what car it is for and we can help you out with what to get!
Old Oct 28, 2003 | 06:13 PM
xenocron's Avatar
Its a 91 integra....
http://www.onlinemetals.com/me...id=71
this site seems pretty reasonable with price, and its T6 6061 aluminum...
I bought 2 180's 2.5" OD, 1 90 2.5" OD, 1 180 2" OD, 1 90 2" OD from Kteller, I thought that would be enough but didnt realize his bends dont begin as long as the steel piping that JC Whitney sells that the one kid uses in his tutorial on how/where to cut to make bends.
So I think i might need a few feet of straight piping...maybe one or two more bends for mistakes as well.
Old Oct 28, 2003 | 06:56 PM
redboost10's Avatar
thanks for setting me straight
Old Oct 28, 2003 | 07:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">thanks for setting me straight</TD></TR></TABLE>
We do what we can.
thegatekeeper14
Welding / Fabrication
18
Apr 19, 2011 07:50 PM
zcrx2006
Sep 30, 2007 03:31 PM
adseguy
Oct 4, 2004 04:07 PM
DamonBoost
Jun 24, 2002 06:03 PM
