Is the air temp sensor used in Crome?
Does Crome use the air temperature sensor? I extended the wires for the sensor and plugged it into my Greddy air filter. I would like to just run a filter on the turbo inlet. Is this sensor doing anything?
If the sensor is an OBD-II style, since it is running a chipped OBD-I ECU, you can easily swap to a flanged type sensor and weld a flange on the charge pipe and place the sensor there.
On a few occasions, I just machine a custom adapter with an O-ring and set-screw so I can still place an OBD-II style IAT sensor on the charge pipe with no leaks/popping off under boost.
I try to avoid putting the IAT sensor on the intake manifold, or at the air filter. One will register heatsoaked readings, one will register ambient temps (and not your charged air temps).
The sensor was placed there due to simplicity, and good enough to get the job done. The IAT sensor is only responsible for up to 10% fuel corrections anyway, and GReddy kits aren't what you call best in terms of a well tuned turbo setup with a blue box they supply with the kit, or a basic E-manage blue.
They did it because the electronics they provide aren't exaclty top-notch in terms of precision or accuracy. Placing it in the pipes, on which they'd have to weld on a special machined flange at an overall high price for such a small performance improvement.
Cliffs: Greddy is just like any other company - they'll save a buck (or overcharge!) when ever possible. One only has to look at their replacement BOV diaphragms to understand.
