Hey guys, I have a problem right now. I have everything finished for installing my turbo kit just my AFC is stupid... Apparently, the APEXI AFC only supports up to Integra 98... I have a 2001 LS integra and the wires don't match up. I just found out my ECM (or whatever its called) has 4 plugs and not 3 like the older models. Anyone with a 99 and up have an AFC working???? I need the wire diagram so I know what wire color matches to what. Apexi support SUCKS and will not help. Any imformation would be helpfull , thanks
HELPPPPPPPPPPP.... anyone????
yeah i have a 95 ls and its all messed up for mine to, i had to do some work with a voltmeter. i wouldn't want to do it again like that. apex tech sucks. if you had an obd1 i'd just tell you which ones to use, but good luck anyways.
Tell me what wires you need to tap and I'll tell you the locations.
Im looking for the MAP sensor wire. What color matches that one?
Go on the paexi web site if you dont have a new VAFC , They started coming wit supplimental schematics a while ago that had the correct wiring on them , and wiring for the newer cars, i had a hell of a time with mine too
MAP is white/yellow on pin C17.
yeah i got that far but my ecu doesnt have that color. lol 2001 different then 99 models. so if u can find the map sensor color for a 2001 then that would be great. thanks for the help
That color is straight out of the '01 Helms. Are you color blind?yeah i got that far but my ecu doesnt have that color. lol 2001 different then 99 models. so if u can find the map sensor color for a 2001 then that would be great. thanks for the help
Just screw the color. Find the wire on C17 and tap into it.
Hey boomslang or anyone.... I know the color is suppose to be White and yellow but there is no such color on my ECU. Can anyone be sure its pin C17 b/c I don't know what will happen if I connect this to the wrong wires. Anyone have a VOLT meter reading for the MAP Sensor so I can test to be sure it's correct. thanks
