Aem fuel rail fitting. Which one
Old Apr 29, 2017 | 04:11 AM
cityofcaterpillars's Avatar
Default Aem fuel rail fitting. Which one
I need to order the fitting for my AEM rail so I can use the OEM fuel line. Do I need the one with the hole or without. The OEM rail doesn't have the hole but I just wanted to double check before I order.
Old Apr 29, 2017 | 07:26 AM
mayfly's Avatar
Default Re: Aem fuel rail fitting. Which one
when i ordered mine, i ordered PART #:2-603. it has the hole for the banjo bolt. the issue i had was that the threads did not match up, but back then i was in a pinch and "stripped" them on. never leaked for 2 years. its not ideal but it works.
the correct thread pitch i needed was PART #:2-602 but it didn't have the hole.
if i was to go back i would get the second one and drill a small hole. after all of that i found out that as long as you have the correct "free flow" head, you do not need the banjo hole in the stud.
usdmEHboy
Feb 23, 2013 04:02 PM
JDMCRX
Jun 14, 2011 07:49 PM
Jorsher
13
Jan 19, 2010 04:52 PM
smash fascism
Apr 10, 2005 01:03 PM
Phaze2 Mike
Jan 15, 2004 11:42 AM
