AEM EMS boost solenoid install
Old May 12, 2010 | 07:14 PM
GSRDEAN's Avatar
Default AEM EMS boost solenoid install
Hello, I finnally just finished the turbo install on my 94 Integra gsr with ems 1040 box and phearable.net base tune. When you look at the diagram from aem for the pin location it says connect one wire to switched 12 volts and the other to pin c10. Their is no connector for c on the ems, so what I did was put a connector on the wire and attached it to that pin. Can anyone tell if I did the right thing or is their another wire I should be goin for. Im getting tuned next Monday so I just want to make sure everything is right before I go. Thanks for any input
Old May 12, 2010 | 08:10 PM
Muckman's Avatar
Moderator in Chief
Default Re: AEM EMS boost solenoid install
You can choose the output for the PWM. I use A11.
Old May 13, 2010 | 05:02 AM
96 GSR-T's Avatar
Old May 13, 2010 | 05:28 AM
GSRDEAN's Avatar
Ok great, will I be cutting the wire and hooking in up or putting the wire inline with that wire? Thanks
Old May 20, 2010 | 07:00 PM
Muckman's Avatar
Moderator in Chief
There shouldnt be a wire in that pin. Your 30-1040 PDF will list which pins can be used for outputs.
Old Jan 3, 2013 | 01:56 PM
rayBans's Avatar
can you guys provide a graph for this? much appreciated !
Old Jan 3, 2013 | 07:17 PM
wantboost's Avatar
Who is Mr Robot?
There is no graph. Look at the pin out AEM provides and figure out what you want to use as an output, add a pin to the ecu connector then wire it up.
Old Jan 3, 2013 | 09:52 PM
rayBans's Avatar
wantboost, my problem is this particular car i just purchased (b18c1 em1) has the aem boost solenoid with a hack *** wire job running from the solenoid to the s300. by accident i unplugged the wire from the ecu and now need to know to which pin is is the correct one to re-wire it to. hope thats clear enough. thanks
Old Jan 9, 2013 | 12:05 AM
rayBans's Avatar
^ Any thoughts or suggestions?
Old Jan 9, 2013 | 12:07 AM
wantboost's Avatar
Who is Mr Robot?
Can you take pictures of the wiring where it connects to the solenoid and at the ecu? There are so many different possibilities that pictures are needed to assist you
Old Jan 13, 2013 | 01:19 AM
rayBans's Avatar
I have a chipped (s300) p28 and from the info I gathered it looks to be pin a11
Old Jan 13, 2013 | 03:08 AM
wantboost's Avatar
Who is Mr Robot?
I need pics of how the solenoid was wired
mmcsiggi
Engine Management and Tuning
Jun 16, 2012 08:25 AM
underpressure02
Mar 10, 2005 01:39 PM
iiilgsrlll
Sep 25, 2004 11:49 PM
99lsvtecauto
Aug 26, 2003 05:42 AM
