Aem ems, 3bar needed?
Im going to be getting and ems soon, and i plan on running 14+ psi. So ive read that i will need the gm 3bar, what i was wondering is will i also need the "pigtail"? (not even sure what it is)
its all for a 94 ls.
I believe that is the harness that connects to the sensor. Camp1320.com has a special on the sensor w/o pigtail for $49. I think summit, jeg's and/or JCwhitney carries the pigtail to match with the sensor.
You can buy the 3bar map sensor from Garage Kwai.
As for the pigtail, you can go into your local autozone and pick up a throttle position sensor harness from a company called Conduct Tite. All you have to do is cut the slots to make it fit. It goes for $10.00. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NyQuiL »</TD></TR><TR><TD CLASS="quote">whats the 3bar usually retail for?</TD></TR></TABLE>
from summit they are like 55 + shipping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi »</TD></TR><TR><TD CLASS="quote">I believe that is the harness that connects to the sensor. Camp1320.com has a special on the sensor w/o pigtail for $49. I think summit, jeg's and/or JCwhitney carries the pigtail to match with the sensor.</TD></TR></TABLE>
I just checked camp1320's site. http://www.camp1320.com/specials.html
It is $59. If you do a search on here you can find the 3-bar map part # you need from summit... or order it from camp1320.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyphear »</TD></TR><TR><TD CLASS="quote">
It is $59. If you do a search on here you can find the 3-bar map part # you need from summit... or order it from camp1320.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=605178
It is $49.
And, summit has the pigtail for separate sale.
It is $49.
