Aem 5bar map sensor on hondata s300?
Old Mar 25, 2007 | 09:32 AM
integraboosted's Avatar
Default Aem 5bar map sensor on hondata s300?
Can I use an aem 5 bar map sensor on a hondata s300? Or do I have to go with gm 3 bar map sensor because im going over 30lbs of boost thanks.
Old Mar 25, 2007 | 09:36 AM
SOHC_MShue's Avatar
Default Re: Aem 5bar map sensor on hondata s300? (integraboosted)
you can use the aem
Old Mar 25, 2007 | 09:38 AM
nebulight's Avatar
You can use whatever sensor you want, just make sure the ECU knows what size. I, personally, think that the AEM 5 bar is WAY over kill. That will read up to 58psi! Most turbo hondas don't boost that high, and a major downside to using a 5bar is you'd lose resolution of the signal. Because every map sensor is is 5v based, that voltage is scaled a lot differently with a 5bar. Most SEMs can do well with a 5bar because it can read that voltage better, I don't know about hondata though. If you are going to like 32-33 psi, I'd go with the AEM 3.5 bar map (which can read up to 36psi). It all depends on your application though.
PARADOX_sf
Dec 12, 2012 12:59 PM
88YellowRexSi
Nov 30, 2005 10:35 AM
vtekthis
Apr 10, 2005 06:00 AM
int3gra
Jul 4, 2003 11:49 AM
