advantages of backdoor intercooler
Old Mar 3, 2009 | 11:23 AM
b20beast83's Avatar
Default advantages of backdoor intercooler
Im not sure if this has been discussed before but SEARCH SUCKS
What are some advantages and disadvantages of a backdoor intercooler?
I know one disadvantage is NO AC
Old Mar 3, 2009 | 11:44 AM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: advantages of backdoor intercooler
I know one of the big advantages, especially those of us with the EF chassis is space. With a traction bar and tight fitment with everything else, there is VERY little room to run piping on the hot side. The backdoor style makes it very easy to run straight to the turbo. It looks cool too I guess? lol
Old Mar 3, 2009 | 11:49 AM
418whpturboD's Avatar
shorter piping, but i have found that the backdoor intercoolers are much more expensive since you have to get them made usually..
Old Mar 3, 2009 | 12:38 PM
Schister66's Avatar
Man U FTW
The biggest advantage of backdoor IC's is that you can cut out a few feet worth of piping. This aids not only in faster spool, but also in greater throttle response since it takes the air from the turbo less time to get to the intake manifold. The downside is the additional cost...
Old Mar 3, 2009 | 03:45 PM
cyrus_gremlins's Avatar
good info...was wondering the same
Old Mar 3, 2009 | 05:01 PM
CTD-Fab's Avatar
I have a dual backdoor with AC
One other disadvantage is that in most cases the IC is not centered But they do tend to work very well.
Old Mar 3, 2009 | 06:30 PM
miller's Avatar
I have yet to ever see a backdoor intercooler increase the spool time by any noticeable difference.
The ONLY benefit I see of the backdoor intercoolers is space and one less place to have a pipe blow off or leak.
Old Mar 3, 2009 | 07:22 PM
Garcia-Racing's Avatar
How do they compare to conventional style I.C. as far as pressure drop? It seems like it would be horrible because of the 90 degree angle. Anyone tested it yet?
Old Mar 3, 2009 | 07:45 PM
The G2 Racer's Avatar
Big advantage for me is easier to run piping.
Old Mar 4, 2009 | 06:04 AM
b20beast83's Avatar
do you have pics
i would like to see it
Old Mar 4, 2009 | 06:23 AM
miller's Avatar
I have had a few cars I tune that went from normal style intercoolers with the outlets on either end to dual backdoor style setups because of the bigger cores and the only thing we noticed was more power in the higher boost levels due to the cooler being more efficent.
Old Mar 4, 2009 | 06:42 AM
redboost10's Avatar
how is it more efficient? shorter piping? or are you comparing cores here as well?
Old Mar 4, 2009 | 06:43 AM
TheShodan's Avatar
Moderator
Pressure drop deals more with the IC CORE than it would the piping.
Old Mar 4, 2009 | 07:00 AM
Angle of entry is also a factor. I know the core is the biggest factor, I'm just wondering if anyone has monitored it at all.
Old Mar 4, 2009 | 07:08 AM
lilsicsoul's Avatar
PiCs??
I never seen this befor/...
Old Mar 4, 2009 | 08:23 AM
97_coupe's Avatar
Originally Posted by lilsicsoul
PiCs??
https://honda-tech.com/forums/showth...light=backdoor
Old Mar 4, 2009 | 12:36 PM
Honda Bull's Avatar
It was the cores and endtanks themselves that allowed for a bit more efficiency. Nothing to do with piping. Generally, on our setups, pipes are pipes unless they are made of different material. They direct a substance to where it needs to go.
Old Mar 4, 2009 | 12:40 PM
redboost10's Avatar
ok i wasnt sure what miller was meaning when saying the backdoor setup was more efficient. what two cores were you comparing? same brand/different dimensions?
Old Mar 6, 2009 | 05:50 AM
miller's Avatar
I wasnt referring to the backdoor as being more efficent due to it being backdoor but I was referring to the cores being more efficent that were on these cars. Like i stated earlier, I saw no spool up difference or power difference until higher boost levels and that is all the core itself. I do believe if the piping was the same and just the cores were different then you would see the same gains in the higher boost levels.
I have had cars that have tons of excessive piping due to the way the intercooler piping was done and when i compare data to a car with shorter piping and other wise very similiar setups the difference isnt even noticeable.
Old Mar 6, 2009 | 06:17 AM
redboost10's Avatar
thanks for clearing that up miller. good info for sure
Old Mar 11, 2009 | 11:52 AM
CTD-Fab's Avatar
Originally Posted by b20beast83
do you have pics
I'll see if I can dig up some pix. The setup was designed by me, single cam, it uses a custom twinscroll manifold with twinscroll turbo that should top out @ around 3-350 hp, everything compatible, full 3" off turbo.
A similar setup on a d15 three stage netted 220hp on 13 psi with a much smaller exhaust and intercooler setup. He fabricated a really cool side mount intercooler for ultimate sleeper status.
Old Mar 11, 2009 | 12:13 PM
Si Trav's Avatar
an advantage of running a backdoor intercooler on a 99-00 Si or any EK with a 99-00 front end conversion is you can retain your fog lights. my end tanks on my regular FMIC were touching the fog lights so I had to remove them and go with a bumper that didn't have holes in the bumper for fogs(unless I wanted my pipes hanging out)
ashtons300zx
Dec 13, 2011 10:12 PM
b20vcrxsir
Feb 8, 2009 04:38 PM
kenbo21
Honda Civic (2001 - 2005)
Aug 27, 2008 08:45 AM
eg:R
Nov 30, 2005 12:36 AM
