Adjusting Comptech's Fuel Pressure Regulator
Old Apr 20, 2006 | 09:25 AM
j32asc's Avatar
Default Adjusting Comptech's Fuel Pressure Regulator
I can't figure out how to adjust Comptech's fuel pressure regulator. These are the directions I was given by someone else.
You need to loosen the nut with a box wrench then turn the adjustment with an Allen wrench while you have the box wrench on the nut..... After you adjust it, tighten the nut back down while holding the Allen wrench in place.
Can someone help with their expertise. And if possible could you mark up the photo below so I can get a visual of the nuts and bolts that needs to be adjusted.
Old Apr 20, 2006 | 10:43 AM
cuin9sec
Guest
Posts: n/a
its the gold bolt in the side. loosen the gold nut at the bottom then use a allen wrench to adjust the pressure.
Old Apr 20, 2006 | 10:56 AM
delacampos's Avatar
Default Re: (gt42r_civic)
are you sure? i'm pretty sure it's the black nut on the left that needs to be loosened and then adjust the threaded piece in the center of that.
Old Apr 20, 2006 | 12:08 PM
j32asc's Avatar
Default Re: (delacampos)
Yeah i just found out that it is the black nut on the left hand side.
j32asc
Apr 20, 2006 12:07 PM
masteryoda10
Feb 15, 2006 07:52 AM
jordan88
Aug 6, 2004 10:42 AM
navin
Feb 20, 2004 06:20 PM
range
Dec 19, 2003 03:02 PM
